Добрый вечер.
Помогите в настройке радиоканала между 2- мя RB SXT 5nd r2.
Проблема в больших потерях пакетов.
Одна точка настроена в режиме бриджа, вторая бридж стайшн.
CCQ 13%/40% выше не поднимается(((
Конфигурации:
Base (бридж):
# sep/27/2015 22:22:05 by RouterOS 6.32.2
# software id = 08V8-99GS
/interface bridge
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6,7 band=\
5ghz-a/n basic-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps country=russia \
disabled=no guard-interval=long mode=bridge nv2-preshared-key=0060508 \
nv2-security=enabled ssid=PrivateChannel tx-power=-3 tx-power-mode=\
all-rates-fixed wds-default-bridge=bridge1 wds-mode=dynamic \
wireless-protocol=nv2
/interface wireless nstreme
set wlan1 disable-csma=yes enable-nstreme=yes framer-policy=dynamic-size
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/queue type
set 1 pfifo-limit=500
set 2 kind=pfifo pfifo-limit=500
/interface bridge port
add bridge=bridge1 interface=ether1
add bridge=bridge1 interface=wlan1
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=bridge1
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=Base
/system leds
set 0 interface=wlan1
Client (station bridge):
# sep/27/2015 22:25:27 by RouterOS 6.32.2
# software id = XZTD-1ELG
/interface bridge
add name=bridge1
/interface wireless
disabled=no frequency=5185 guard-interval=long mode=station-bridge \
nv2-preshared-key=0060508 nv2-security=enabled ssid=PrivateChannel \
tx-power=0 tx-power-mode=all-rates-fixed wds-default-bridge=bridge1
set wlan1 enable-nstreme=yes
/queue type
/ip dhcp-client
interface=bridge1
/system clock
/system identity
set name=Client
/system leds
