sbubnom_
Новичок
  • Публикации
    5
  • Зарегистрирован
  • Посещение
О sbubnom_
  • Звание
    Абитуриент
  1. Помогите с маршрутизацией
    В данный момент R1 работает с такими настройками: /ip address add address=10.10.100.2/24 interface=WAN1 network=10.10.100.0 add address=10.10.101.2/24 interface=WAN2 network=10.10.101.0 add address=10.10.102.2/24 interface=WAN3 network=10.10.102.0 add address=10.10.10.1/24 interface=HomeLAN network=10.10.10.0 /ip firewall address-list add address=10.10.10.101 comment="Tuner" list=WAN1_M add address=10.10.10.102 comment="PHONE" list=WAN2_R add address=10.10.10.103 comment="PHONE2" list=WAN2_R add address=10.10.10.104 comment="NOTEBOOK1" list=WAN1_80,443,110,25 add address=10.10.10.105 comment="NOTEBOOK2" list=WAN_ECMP /ip firewall nat add action=masquerade chain=srcnat dst-port=80,443,110,25 out-interface=WAN1 protocol=tcp src-address-list=WAN1_80,443,110,25 add action=masquerade chain=srcnat comment=NAT-WAN1 dst-address=!10.10.10.0/24 src-address-list=WAN1_M add action=masquerade chain=srcnat comment=NAT-WAN2 dst-address=!10.10.10.0/24 src-address-list=WAN2_R add action=masquerade chain=srcnat comment=NAT-WAN3 dst-address=!10.10.10.0/24 src-address-list=WAN3_L add action=masquerade chain=srcnat comment=ECMP_Balance src-address-list=WAN_ECMP /ip firewall mangle add action=mark-routing chain=prerouting comment=WAN1_80,443,110,25 dst-port=80,443,110,25 new-routing-mark=WAN1_80,443,110,25 passthrough=no protocol=tcp src-address-list=WAN1_80,443,110,25 add action=mark-routing chain=prerouting comment=ROUTE-WAN1 new-routing-mark=ROUTE-WAN1 passthrough=no src-address-list=WAN1_M add action=mark-routing chain=prerouting comment=ROUTE-WAN2 new-routing-mark=ROUTE-WAN2 passthrough=no src-address-list=WAN2_R add action=mark-routing chain=prerouting comment=ROUTE-WAN3 new-routing-mark=ROUTE-WAN3 passthrough=no src-address-list=WAN3_L add action=mark-connection chain=input comment=ECMP_Balance in-interface=WAN1 new-connection-mark=cin_WAN1 src-address-list=WAN_ECMP add action=mark-connection chain=input comment=ECMP_Balance in-interface=WAN2 new-connection-mark=cin_WAN2 src-address-list=WAN_ECMP add action=mark-connection chain=input comment=ECMP_Balance in-interface=WAN3 new-connection-mark=cin_WAN3 src-address-list=WAN_ECMP add action=mark-routing chain=output comment=ECMP_Balance connection-mark=cin_WAN1 new-routing-mark=ECMP_ROUTE_WAN1 passthrough=no add action=mark-routing chain=output comment=ECMP_Balance connection-mark=cin_WAN2 new-routing-mark=ECMP_ROUTE_WAN2 passthrough=no add action=mark-routing chain=output comment=ECMP_Balance connection-mark=cin_WAN3 new-routing-mark=ECMP_ROUTE_WAN3 passthrough=no add action=mark-routing chain=prerouting comment=ECMP_Balance new-routing-mark=ECMP_MIXED src-address-list=WAN_ECMP /ip route add comment=WAN1_80,443,110,25 distance=1 gateway=10.10.100.1 routing-mark=WAN1_80,443,110,25 add comment=ROUTE-WAN1 distance=1 gateway=10.10.100.1 routing-mark=ROUTE-WAN1 add comment=ROUTE-WAN2 distance=1 gateway=10.10.101.1 routing-mark=ROUTE-WAN2 add comment=ROUTE-WAN3 distance=1 gateway=10.10.102.1 routing-mark=ROUTE-WAN3 add comment=ECMP_Balance distance=1 gateway=10.10.101.1,10.10.100.1,10.10.102.1 routing-mark=ECMP_MIXED add check-gateway=ping comment=ECMP_Balance distance=1 gateway=10.10.100.1 routing-mark=ECMP_ROUTE_WAN1 add check-gateway=ping comment=ECMP_Balance distance=1 gateway=10.10.101.1 routing-mark=ECMP_ROUTE_WAN2 add check-gateway=ping comment=ECMP_Balance distance=1 gateway=10.10.102.1 routing-mark=ECMP_ROUTE_WAN3 add comment=DNS2 distance=1 dst-address=8.8.4.4/32 gateway=10.10.100.1 add comment=DNS1 distance=1 dst-address=8.8.8.8/32 gateway=10.10.100.1 По статтье в инете настроил ECMP Load Balancing. Не будет ли конфликтов каких-то? Пока вроде работает и балансировка, и пользователи ходят по своим маршрутам. А если мне нужно, чтобы пользователь 10.10.10.101/24 ходил через VPN на R2? Как реализовать?
  2. Доброго времени суток! 1. R1 и R2 находятся в одной сети - 10.10.10.0/24 2. R1 - Является шлюзом для WORK_1-5. А также для Роутера R2 3. R2 - Является шлюзом для SERVER_1-3 Как сделать, чтобы WORK_1-5 ходили в инет через VPN_1-5? А SERVER_1-3 ходили в инет через VPN_6? Как правильно прописать NATы на роутерах R1,R2? Нстройки R1: ether1 - WAN1 ether2 - WAN2 ether3 - WAN3 ether5 - LAN to R2 Настройки R2: ether1 - LAN to R1 ether2-5 - SWITCH 10.10.11.1/24 ether1-2 - Bridge Прошу не пинать сильно, в сетях - новичёк. Заранее благодарен за информацию и помощь.
  3. Статический маршрут к серверу
    sbubnom_, Спасибо. Сделал, работает! DRiVen, понимаю Ваш сарказм. Но дело в том, что 2-МТ используется для поднятия VPN-нок для всего, что к нему подключено. а 1-МТ он просто для домашней сети.
  4. Доброго времени суток, уважаемые форумчане! Такая задача: Есть 2 Микротика: 1 - Раздаёт интернет в домашнюю сеть 10.10.10.0/24 с адресом 10.10.10.1 , шлюз в инет 10.10.100.1 (DSL модем) 2 - Должен раздавать инет во вторую сеть 10.10.11.0/24, сам Микротик имеет адрес 10.10.10.10, шлюзом выступает 1-Микротик - 10.10.10.1 Вопрос, как правильно организовать маршрутизацию к серверу 10.10.11.50, который подключён к 2-Микротику через 1-Микротик, для компьютеров с сети 10.10.10.0/24 ?
