Здравствуйте! Установил точку доступа Mikrotik OmniTIK UPA-5HnD. У всех клиентов устройства пишут, что неправильный пароль и не подключаются, поставили максимально простой пароль - не помогло, проверяли этот конфиг на 2ГГЦ точке - нет такой ошибки. Подскажите - в чем может быть проблема? выкладываю конфиг ниже.
# oct/21/2015 15:39:11 by RouterOS 6.32.2
/interface bridge
add mtu=1500 name=bridge-local
/interface ethernet
set [ find default-name=ether1 ] name=ether1-LAN1
set [ find default-name=ether2 ] name=ether2-LAN1
set [ find default-name=ether3 ] name=ether3-LAN1
set [ find default-name=ether4 ] name=ether4-LAN1
set [ find default-name=ether5 ] name=ether5-LAN1
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm \
mode=dynamic-keys name=profile_local_wi-fi supplicant-identity="" \
unicast-ciphers=tkip,aes-ccm wpa2-pre-shared-key=12345678
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
profile_guest_wi-fi supplicant-identity="" wpa2-pre-shared-key=12345678
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
band=5ghz-a/n country=russia disabled=no distance=indoors frequency=auto \
hw-protection-mode=rts-cts mode=ap-bridge noise-floor-threshold=-100 \
rx-chains=0,1 security-profile=profile_local_wi-fi ssid=Main \
tx-chains=0,1 wireless-protocol=802.11 wmm-support=enabled
add disabled=no mac-address=4E:5E:0C:68:54:71 master-interface=wlan1 name=\
"Guest Wi-Fi" security-profile=profile_guest_wi-fi ssid=Guest \
wds-cost-range=0 wds-default-cost=0 wmm-support=enabled
/ip pool
add name=dhcp_pool_guest ranges=172.17.16.100-172.17.16.140
/ip dhcp-server
add address-pool=dhcp_pool_guest disabled=no interface="Guest Wi-Fi" \
lease-time=12h name=dhcp_guest
/queue simple
add max-limit=5M/5M name="Guest Wi-Fi Limitation" target="Guest Wi-Fi"
/snmp community
set [ find default=yes ] addresses=1.1.1.1/32
/interface bridge port
add bridge=bridge-local interface=ether1-LAN1
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether2-LAN1
add bridge=bridge-local interface=ether3-LAN1
add bridge=bridge-local interface=ether4-LAN1
add bridge=bridge-local interface=ether5-LAN1
/ip address
add address=172.16.5.3/24 interface=bridge-local network=172.16.5.0
add address=172.17.16.1/24 interface="Guest Wi-Fi" network=172.17.16.0
/ip dhcp-server network
add address=172.17.16.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=172.17.16.1
/ip dns
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall filter
add action=drop chain=forward comment="Deny guest reguests" dst-address=\
172.17.16.0/24 src-address=172.16.5.0/24
172.16.5.0/24 src-address=172.17.16.0/24
/ip firewall nat
add action=masquerade chain=srcnat out-interface=bridge-local src-address=\
172.17.16.0/24
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip route
add distance=1 gateway=172.16.5.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=172.16.5.0/24
set api disabled=yes
set api-ssl disabled=yes
/snmp
set enabled=yes
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Moscow
/system identity
set name="AIR1"
/system ntp client
set enabled=yes primary-ntp=46.254.216.9 secondary-ntp=95.213.132.254
В логе при этом встречается ошибка - disconnected, unicast key exchange timeout
Проблема была в плохом сигнале. Решено- может кому пригодиться :)
