У меня такая же проблема в город (FXO) можно звонить, из города нет.
У меня такое устройство:
cisco-2fxo#show version
Cisco Internetwork Operating System Software
IOS (tm) C1700 Software (C1700-IPVOICE-M), Version 12.3(23), RELEASE SOFTWARE (fc5)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 24-Jul-07 14:47 by stshen
Image text-base: 0x8000816C, data-base: 0x81455D6C
ROM: System Bootstrap, Version 12.2(4r)XL, RELEASE SOFTWARE (fc1)
cisco-2fxo uptime is 15 minutes
System returned to ROM by reload at 12:05:11 Moscow Wed May 27 2015
System restarted at 12:07:15 Moscow Wed May 27 2015
System image file is "flash:c1700-ipvoice-mz.123-23.bin"
cisco 1760 (MPC860P) processor (revision 0x200) with 59225K/6311K bytes of memory.
Processor board ID FOC071218L4 (1906716500), with hardware revision BB67
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
2 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
cisco-2fxo#
Также после прочтения этой ветки форума переделал свой конфиг на следующий:
cisco-2fxo#show running-config
Building configuration...
Current configuration : 2141 bytes
! No configuration change since last restart
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname cisco-2fxo
boot-start-marker
boot system flash:c1700-ipvoice-mz.123-23.bin
boot system flash:c1700-sv3y-mz.123-26.bin
boot-end-marker
enable secret 5 $1$G2kC$.k32309gSDYcDmcwRXZYh.
clock timezone Moscow 3
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 1
no aaa new-model
ip subnet-zero
ip cef
voice service pots
voice service voip
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice class codec 2
codec preference 1 g711ulaw
codec preference 3 g729r8
interface Ethernet0/0
no ip address
shutdown
half-duplex
interface FastEthernet0/0
ip address dhcp hostname cisco-2fxo
speed auto
ip classless
no ip http server
voice-port 1/0
supervisory disconnect dualtone mid-call
no non-linear
no vad
no comfort-noise
cptone RU
connection plar 551
impedance complex1
description tel 53-09-31
station-id name 53-09-31
caller-id enable
voice-port 1/1
input gain 6
output attenuation 0
no comfort-noise
cptone RU
timeouts initial 30
timeouts call-disconnect 3
timeouts wait-release 10
connection plar 552
impedance complex1
description tel 53-93-00
station-id name 53-93-00
dial-peer voice 1 pots
destination-pattern 703......
port 1/0
forward-digits 6
dial-peer voice 2 pots
destination-pattern 704......
port 1/1
forward-digits 6
dial-peer voice 10 voip
description all
destination-pattern 55[12]
voice-class codec 2
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
no vad
sip-ua
sip-server ipv4:192.168.51.13:5060
line con 0
line aux 0
line vty 0 4
password 12345
login
ntp clock-period 17208540
ntp server 195.2.64.6
ntp server 192.168.51.1
end
cisco-2fxo#
Астериск имеет следующий конфиг
[703]
type=friend
host=192.168.51.14
qualify=yes
qualifyfreq=10
disallow=all
allow=ulaw
allow=alaw
context=main
;port=5060
nat=no
insecury=port,invite
[704]
type=peer
host=192.168.51.14
qualify=yes
qualifyfreq=10
disallow=all
allow=ulaw
allow=alaw
context=main
nat=no
Звоню в город по следующему экстеншену
exten => _XXXXXX,1,Dial(SIP/192.168.51.14/703${EXTEN},60)
exten => _XXXXXX,n,HangUp()
Проблема в следующем:
При звонке на FXO из города идет два гудка и занято.
Звонки в город проходят нормально.
Думаю второй день где накосячил?
