dm001
Новичок
  • Content Count
    3
  • Joined
  • Last visited
About dm001
  • Rank
    Абитуриент
  1. Добрый день! Имею практически аналогичную ошибку как у max1976 root@cs:~/RKN# ./zapret.pl perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = "en_US:en", LC_ALL = (unset), LC_CTYPE = "UTF-8", LANG = "en_US.UTF-8" are supported and installed on your system. perl: warning: Falling back to the standard locale ("C"). Use of uninitialized value $lastDumpDateOld in concatenation (.) or string at ./zapret.pl line 170. Use of uninitialized value $lastAction in concatenation (.) or string at ./zapret.pl line 171. Use of uninitialized value $lastCode in concatenation (.) or string at ./zapret.pl line 172. Use of uninitialized value $lastResult in concatenation (.) or string at ./zapret.pl line 173. Use of uninitialized value $lastResult in string eq at ./zapret.pl line 181. Subroutine _call redefined at (eval 132) line 50. Subroutine OperatorRequestService::want_som redefined at (eval 132) line 92. Subroutine AUTOLOAD redefined at (eval 132) line 109. Subroutine OperatorRequestService::getLastDumpDateEx redefined at (eval 132) line 107. Subroutine OperatorRequestService::sendRequest redefined at (eval 132) line 107. Subroutine OperatorRequestService::getResult redefined at (eval 132) line 107. Subroutine OperatorRequestService::getLastDumpDate redefined at (eval 132) line 107. Subroutine _call redefined at (eval 139) line 50. Subroutine OperatorRequestService::want_som redefined at (eval 139) line 92. Subroutine AUTOLOAD redefined at (eval 139) line 109. Subroutine OperatorRequestService::getLastDumpDateEx redefined at (eval 139) line 107. Subroutine OperatorRequestService::sendRequest redefined at (eval 139) line 107. Subroutine OperatorRequestService::getLastDumpDate redefined at (eval 139) line 107. Subroutine OperatorRequestService::getResult redefined at (eval 139) line 107. Subroutine _call redefined at (eval 146) line 50. Subroutine OperatorRequestService::want_som redefined at (eval 146) line 92. Subroutine AUTOLOAD redefined at (eval 146) line 109. Subroutine OperatorRequestService::getLastDumpDate redefined at (eval 146) line 107. Subroutine OperatorRequestService::getResult redefined at (eval 146) line 107. Subroutine OperatorRequestService::sendRequest redefined at (eval 146) line 107. Subroutine OperatorRequestService::getLastDumpDateEx redefined at (eval 146) line 107. root@cs:~/RKN# tailf -50 /var/log/zapret_update.log 2016-03-02 13:18:42 | INFO | main | Starting RKN at Wed Mar 2 13:18:42 2016 2016-03-02 13:18:43 | ERROR | main | Soap result not defined, retrying... 2016-03-02 13:18:43 | ERROR | main | Soap result not defined, retrying... 2016-03-02 13:18:43 | ERROR | main | Soap result not defined, retrying... 2016-03-02 13:18:43 | ERROR | main | Soap result not defined, retrying... 2016-03-02 13:18:43 | FATAL | main | 3 attempts failed, giving up. Какие возможные варианты? SOAP::Lite установлен последней версии, версия скрипта свежая из git ( https://github.com/ircop/zapret )
  2. Добрый день, господа, аналогичным образом получил следующее письмо: Подскажите, пожалуйста, что в данной ситуации корректнее ответить при условии, что официально зарегистрирован только один узел связи и фильтрация осуществляется на уровне программного обеспечения под nix без использования таких решений как Cisco SCE?
