daffoff
Новичок
  • Content Count
    3
  • Joined
  • Last visited
Everything posted by daffoff
  1. PPtP клиент
    [admin@MikroTik] /ip route> /ip route add dst-address=192.168.100.0/24 gateway=192.168.100.101 pref-src=192.168.254.0/24 invalid value for argument pref-src <<<<<<< ОШИБКА [admin@MikroTik] /ip route> [admin@MikroTik] > interface pptp-client print Flags: X - disabled, R - running 0 R name="pptp-out1" max-mtu=1400 max-mru=1400 mrru=disabled connect-to=x.x.x.x user="************" password="*************" profile=default-encryption keepalive-timeout=60 add-default-route=no dial-on-demand=no allow=pap,chap,mschap1,mschap2 С сервером все в порядке вроде так как до микротика был роутер с openwrt и все было ок Сам микротик нормально пингует все адреса а вот устройствам за собой не дает этого делать :( ============================================================================================== etc/ppp/options.pptpd #debug #logfile /tmp/pptp-server.log 192.168.100.254: auth name "pptp-server" lcp-echo-failure 3 lcp-echo-interval 60 default-asyncmap mtu 1482 mru 1482 nobsdcomp nodeflate proxyarp #nomppc mppe required,no40,no56,stateless require-mschap-v2 refuse-chap refuse-mschap refuse-eap refuse-pap #ms-dns 172.16.1.1 #plugin radius.so #radius-config-file /etc/radius.conf
  2. PPtP клиент
    Может поможет [admin@MikroTik] /ip firewall filter> print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; default configuration chain=forward action=accept connection-state=established,related log=no log-prefix="" 1 ;;; default configuration chain=input action=accept connection-state=established,related log=no log-prefix="" 2 ;;; PING-OFF chain=input action=drop protocol=icmp in-interface=pppoe-out1 log=no log-prefix="" 3 ;;; default configuration chain=input action=drop in-interface=ether1-gateway log=no log-prefix="" 4 ;;; default configuration chain=forward action=drop connection-state=invalid log=no log-prefix="" 5 ;;; default configuration chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1-gateway log=no log-prefix="" [admin@MikroTik] /ip firewall filter> ======================================================================================== [admin@MikroTik] /ip firewall> nat print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; default configuration chain=srcnat action=masquerade out-interface=pppoe-out1 log=no log-prefix="" [admin@MikroTik] /ip firewall>
  3. PPtP клиент
    [admin@MikroTik] /ip route> print Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit # DST-ADDRESS PREF-SRC GATEWAY DISTANCE 0 ADS 0.0.0.0/0 62.x.x.x 1 1 ADC 62.x.x.x/32 62.x.x.x pppoe-out1 0 2 A S 192.168.100.0/24 192.168.254.1 pptp-out1 1 <<< Добавил но опять не выходит 3 ADC 192.168.100.254/32 192.168.100.101 pptp-out1 0 4 ADC 192.168.254.0/24 192.168.254.1 bridge-local 0
