Скорее всего обновления The Dude ждать не стоит... Вот моя переписка с представителями MikroTik
Советуют либо через шедулер либо через API... **************
Hello,
Unfortunately my colleague misinformed you a bit. This problem cannot be solved
without the Dude upgrade, but the project is at the moment been put on hold as we
have more important things to work on in regards of RouterOS development. At the
moment best option would be to create upgrade/maintenance system using API system.
Wiki article on api:
wiki.mikrotik.com/wiki/Manual:API
Regards,
Krisjanis P.
03/03/2015 03:00 - Игорь Гречко wrote:
> Hi!
> I administer a small wireless network (600 units).
> With the release of RouterOS 6.25+ I was faced with the problem of
> automatic update devices.
> Dude packages unknown and can not update the device.
> How to solve this problem?
> Surely no one more experienced with it?
> Why bury Dude? Why is not there any solutions?
> sergejs answered me:
> We are aware of the particular problem, and fix for the issue will be
> present soon.
> Meanwhile for automatic upgrade, I recommend to use simple script.
> /system scheduler
> add name=upgrade on-event="/system package update check-for-updates;\r\
> \n/system package update download;\r\
> \n:delay 60s;\r\
> \n/system reboot;"
> policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=\
> feb/28/2015 start-time=13:55:00
> it is enough for uprade, you can adjust way how it is loaded and how time
> is specified, but idea is simple.
> Ок!!!!
> Yes, but this method is suitable for the equipment on which there is access
> to the Internet. And what about the equipment and the local transport
> network? Only update manually ... And if hundreds of such equipment? When
> will the decision about?
> *P.S. My company bought more than 1000 units of your product and you can
> not even fix the problem with the automatic update via ROS The Dude ... I'm
> very disappointed in Mikrotik : (((*
