спасибо за ответ.. я пробовал так сделать.только не понятка делаю по докам но
config>service>ies>ifa
address allow-directed-broadcasts arp-timeout
*A:AS4>config>service>ies>if# address 192.168.1.2/24
INFO: PIP #1358 The address in not in the valid range
*A:AS4>config>service>ies>if# address 192.168.1.2/29
*A:AS4>config>service>ies>if# address 192.168.1.2/30
*A:AS4>config>service>ies>if# address 192.168.1.2/31
*A:AS4>config>service>ies>if# address 192.168.1.2/32
в доках везде
Example:
A:ALU-41>config>service# ies 5
A:ALU-41>config>service>ies# interface “ATMoIP Management”
A:ALU-41>config>service>ies>if# address 3.3.3.3/24
A:ALU-41>config>service>ies>if# ip-mtu 1524
A:ALU-41>config>service>ies>if# no shutdown
что ему не так??
может я не там смотрю. но каманды secondary нет
config>router>if#
[no] address - Assigns an IP address/IP subnet/broadcast address format to the interface
[no] allow-directed* - Enable/disable forwarding of directed broadcasts on the interface
[no] arp-timeout - Configures timeout for an ARP entry learned on the interface
[no] bfd - Configure BFD parameters
[no] description - Description for the interface
dhcp + Configure DHCP parameters
egress + Configure egress network filter policies for the interface.
icmp + Configure ICMP parameters for the interface
ingress + Configure ingress network filter policies for the interface.
[no] ipv6 + Enables/Configures IPv6 for an interface
[no] ldp-sync-timer - Configure IGP-LDP synchronization timer
[no] loopback - Configure the interface as a loopback interface
[no] lsr-load-balan* - Configure the LSR Load Balancing algorithm for the interface
[no] ntp-broadcast - Enable/disable receiving of NTP/SNTP broadcasts on the interface
[no] port - Bind the interface to a physical port
[no] qos - Associate a network Quality of Service (QoS) policy with the interface
[no] shutdown - Administratively enable/disable the interface
[no] static-arp - Configure a static ARP entry for the interface
см. сообщение 408
спасибо с этим разобрался.. возник другой вопрос
вот кусок конфига:
interface "test"
address xx.xx.xx.xx/30
port 1/1/3:15
exit
interface "test1"
description "test1"
port 1/1/3:10
exit
interface "test2"
description "test2"
port 1/1/3:125
exit
interface "offise"
address xx.xx.xx.xx/28
description "ofiss"
port 1/1/3:141
exit
interface "qwe"
exit
interface "switch"
description "switch"
port 1/1/3:77
exit
interface "system"
address 10.10.3.200/32
exit
interfa
как сделать секондвери адреса и поставить огроничение скрости на них??
С новым годом!
Пробрели alcatel-lusent 7705sar-m нужно настроить bgp я после цыски не совсем пока понимаю логику алкателя по этому оброщяюсь к вам
на cisco
address-family ipv4
no synchronization
network xx.xx.xx.0 mask 255.255.254.0 указываем свою сеть
на alcatel-lusent omniswitch
ip bgp network xx.xx.11.0 255.255.255.0
ip bgp network xx.xx.11.0 255.255.255.0 status enable
а как это сделать на 7705 sar-m ? не могу разобраться. помогите пожалйста
