denlao
Новичок
  • Публикации
    3
  • Зарегистрирован
  • Посещение
О denlao
  • Звание
    Абитуриент
    Абитуриент
  1. Микротик, прошу помощи
    нет, не должен. Да, dns странный, по умолчанию, он пока не нужен. Пинги идут с микротика на 8.8.8.8 например. с локалки до внешнего адреса микротика пинги не идут.
  2. Микротик, прошу помощи
    [admin@MikroTik] > export compact # jan/02/1970 00:02:59 by RouterOS 6.15 # software id = Y72E-B6FL # /interface bridge add admin-mac=4C:5E:0C:34:C1:73 auto-mac=no name=bridge-local /interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\ 20/40mhz-ht-above distance=indoors l2mtu=2290 mode=ap-bridge ssid=\ MikroTik-34C177 /interface ethernet set [ find default-name=ether1 ] name=ether1-gateway set [ find default-name=ether2 ] name=ether2-master-local set [ find default-name=ether3 ] name=ether3-slave-local set [ find default-name=ether4 ] name=ether4-slave-local set [ find default-name=ether5 ] name=ether5-slave-local /ip neighbor discovery set ether1-gateway discover=no /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \ mac-cookie-timeout=3d /ip pool add name=default-dhcp ranges=192.168.88.10-192.168.88.254 /ip dhcp-server add address-pool=default-dhcp disabled=no interface=ether2-master-local \ lease-time=10m name=default /ip address add address=192.168.0.2/24 comment="default configuration" interface=\ ether2-master-local network=192.168.0.0 add address=120.233.245.224/29 interface=ether1-gateway network=\ 120.233.245.225 /ip dhcp-client add comment="default configuration" dhcp-options=hostname,clientid disabled=\ no interface=ether1-gateway /ip dhcp-server network add address=192.168.0.0/24 comment="default configuration" dns-server=\ 192.168.0.2 gateway=192.168.0.2 /ip dns set allow-remote-requests=yes servers=192.168.11.250 /ip dns static add address=192.168.88.1 name=router /ip firewall filter add chain=input src-address=192.168.0.0/24 add chain=input comment="default configuration" protocol=icmp add chain=input comment="default configuration" connection-state=established add chain=input comment="default configuration" connection-state=related add action=drop chain=input comment="default configuration" disabled=yes \ in-interface=ether1-gateway add chain=forward comment="default configuration" connection-state=\ established add chain=forward comment="default configuration" connection-state=related add action=drop chain=forward comment="default configuration" \ connection-state=invalid disabled=yes /ip firewall mangle add chain=prerouting disabled=yes /ip firewall nat add action=masquerade chain=srcnat comment="default configuration" \ out-interface=ether1-gateway src-address-list="" /ip route add distance=1 gateway=120.233.245.226 /ip upnp set allow-disable-external-interface=no /system leds set 0 interface=wlan1 /tool graphing interface add interface=ether1-gateway add interface=ether2-master-local /tool mac-server set [ find default=yes ] disabled=yes add interface=ether2-master-local add interface=ether3-slave-local add interface=ether4-slave-local add interface=ether5-slave-local add interface=wlan1 add interface=bridge-local /tool mac-server mac-winbox set [ find default=yes ] disabled=yes add interface=ether2-master-local add interface=ether3-slave-local add interface=ether4-slave-local add interface=ether5-slave-local add interface=wlan1 add interface=bridge-local
  3. Прошу ткнуть, что не настроил. Уже несколько инструкций попробовал. Все просто, пытаюсь настроить микротик в качестве маршрутизатора. Комп из внутренней сети пингуется с микротиком. Микротик пингует провайдера, все ок. Но нет пинга между внутренней сетью и провайдером и соотвественно нет инета. NAT настраивал!!! Проблема, как понимаю, нет маршрутизации между ether2-master-local и ether1-gateway. Провайдер воткнут в ether1-gateway. Локалка в ether2-master-local. Остальные порты не задействованы. Вот логи. [admin@MikroTik] /ip firewall nat> print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; default configuration chain=srcnat action=masquerade src-address-list="" out-interface=ether1-gateway connection-type="" [admin@MikroTik] > ip address print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK INTERFACE 0 ;;; default configuration 192.168.0.2/24 192.168.0.0 ether2-master-local 1 120.233.245.225/29 120.233.245.224 ether1-gateway [admin@MikroTik] > interface print Flags: D - dynamic, X - disabled, R - running, S - slave # NAME TYPE MTU L2MTU MAX-L2MTU 0 R ether1-gateway ether 1500 1598 4074 1 R ether2-master-local ether 1500 1598 4074 2 ether3-slave-local ether 1500 1598 4074 3 ether4-slave-local ether 1500 1598 4074 4 ether5-slave-local ether 1500 1598 4074 5 X wlan1 wlan 1500 2290 6 R bridge-local bridge 1500 65535 [admin@MikroTik] > ip route print Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit # DST-ADDRESS PREF-SRC GATEWAY DISTANCE 0 A S 0.0.0.0/0 120.233.245.226 1 1 ADC 120.233.245.224/29 120.233.245.225 ether1-gateway 0 2 ADC 192.168.0.0/24 192.168.0.2 ether2-master-l... 0
