День добрый!
Есть несколько ASR1001.
Необходимо проапгрейдить IOS.
Пару из них съели новые
sh ver | inc bin
System image file is "bootflash:/asr1001-universalk9.03.10.02.S.153-3.S2-ext.bin"
никаких проблем.
Но...
Вот с этим идивидумом
sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.1(3)S, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 22:44 by mcpre
Cisco IOS-XE software, Copyright © 2005-2011 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
r1.m9 uptime is 4 days, 2 minutes
Uptime for this control processor is 4 days, 3 minutes
System returned to ROM by reload at 15:23:15 MSK Thu Aug 7 2014
System image file is "bootflash:/asr1001-universalk9.03.04.00.S.151-3.S.bin"
Last reload reason: Reload Command
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
License Info:
License UDI:
Device# PID SN UDI
*0 ASR1001 JAE16120100 ASR1001:JAE16120100
License Package Information for Module:'asr1001'
Module name Image level Pri Config Valid license
asr1001 adventerprise 1 NO adventerprise
advipservices 2 NO advipservices
ipbase 3 NO ipbase
Module name Current Level Reboot Level
asr1001 ipbase ipbase
cisco ASR1001 (1RU) processor with 3851488K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
Configuration register is 0x2102
ни как он не хочет есть новый IOS.
На что думать товарищи? Может лиценции, может просто что то не так делаю.... хотя что может быть не так....
Чувствую ответ где то рядом ..... но не могу найти
