Роутер1
[admin@MikroTik] > export compact
# jan/02/1970 13:43:26 by RouterOS 5.26
# software id = 5S1R-U95T
/interface ethernet
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway name=pppoe-out1 password=123qweQWE use-peer-dns=yes user=tomaskot
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
/ip pool
add name=default-dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server
add address-pool=default-dhcp disabled=no interface=ether2-master-local name=default
/interface pppoe-server server
add disabled=no interface=ether1-gateway service-name=service1
/interface pptp-server server
set enabled=yes
/ip address
add address=192.168.88.1/24 comment="default configuration" interface=ether2-master-local
/ip dhcp-client
add comment="default configuration" disabled=no interface=ether1-gateway
/ip dhcp-server network
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes servers=85.113.62.225,85.113.63.225
/ip dns static
add address=192.168.88.1 name=router
/ip firewall filter
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
/ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add action=masquerade chain=srcnat src-address=192.168.88.0/24
/ip neighbor discovery
set ether1-gateway disabled=yes
/ip route
add distance=1 dst-address=192.168.88.0/24 gateway=192.168.100.2
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
/tool mac-server mac-winbox
set [ find default=yes ] disabled=yes
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
Роутер2
# jan/02/1970 14:14:29 by RouterOS 6.10
# software id = JTUZ-Q4XS
/interface bridge
add admin-mac=D4:CA:6D:EB:F6:EF auto-mac=no l2mtu=1598 name=bridge-local
/interface ethernet
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
ether5-slave-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
20/40mhz-ht-above distance=indoors l2mtu=2290 mode=ap-bridge ssid=\
MikroTik-EBF6F3
set ether1-gateway discover=no
/interface wireless security-profiles
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys wpa-pre-shared-key=4AC702D20585 wpa2-pre-shared-key=\
4AC702D20585
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
/ip pool
/ip dhcp-server
add address-pool=default-dhcp disabled=no interface=bridge-local lease-time=\
10m name=default
/port
set 0 name=usb1
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 \
default-route-distance=1 dial-on-demand=no disabled=no interface=\
ether1-gateway keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=1600 \
name=pppoe-out1 password=pppoe profile=default service-name=pppoe \
use-peer-dns=yes user=pppoe1
/interface ppp-client
add add-default-route=yes allow=pap,chap,mschap1,mschap2 apn=internet \
data-channel=0 default-route-distance=1 dial-command=ATDT dial-on-demand=\
no disabled=no info-channel=0 keepalive-timeout=30 max-mru=1500 max-mtu=\
1500 modem-init="" mrru=disabled name=ppp-out1 null-modem=no password="" \
phone="" pin="" port=usb1 profile=default use-peer-dns=yes user=""
/interface bridge port
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/ip address
add address=192.168.88.1/24 comment="default configuration" interface=\
bridge-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
add address=192.168.88.0/24 comment="default configuration" dns-server=\
/ip dns
/ip dns static
/ip firewall filter
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
add chain=forward comment="default configuration" connection-state=\
established
add action=drop chain=forward comment="default configuration" \
/ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" \
add action=masquerade chain=srcnat out-interface=ppp-out1 to-addresses=\
0.0.0.0
/ip route
add distance=1 dst-address=192.168.88.20/32 gateway=192.168.100.1
/ip upnp
set allow-disable-external-interface=no
/system leds
set 0 interface=wlan1
set 2 interface=ether1-gateway
set 3 interface=ether1-gateway
set 4 interface=ether1-gateway
set 5 interface=ether1-gateway
/tool mac-server
add interface=wlan1
add interface=bridge-local
add interface=wlan1
и это мое последнее сообщение (Вы можете отправить еще 1 сообщений до 09 августа 2014 - 11:47. Данное ограничение будет действовать пока у вас не будет 8 одобренных сообщений.) интересно что дальше делать? )) на всякий случай, для желающих помочь аська 129001850. Спасибо
