Добрый день !
Есть проблема.
Дано: с одной стороны Quidway S2326TP-EI прошивка V100R006C03, с другой стороны NAG-овский коммутатор S2980G.
Есть необходимость сделать между ними линк в 2Gb посредством Link aggregation.
со стороны NAG-овского коммутатора все вроде как нормально:
port-group 1
Interface Ethernet1/25
switchport mode trunk
switchport trunk allowed vlan 10
port-group 1 mode on
Interface Ethernet1/26
Interface Port-Channel1
по крайней мере по show interface port-channel 1 получаю следующее
TP-SW01#show interface port-channel 1
Interface brief:
[b]Port-Channel1 is up, line protocol is up[/b]
Port-Channel1 is layer 2 port, alias name is main trunk, index is 65
Port-Channel1 is LAG port, member is :
Ethernet1/25 Ethernet1/26
Hardware is EtherChannel, address is 02-03-04-05-06-07
PVID is 1
MTU 1500 bytes, BW 2000000 Kbit
Time since last status change:0w-0d-7h-15m-18s (26118 seconds)
Encapsulation ARPA, Loopback not set
Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 2G bits
FlowControl is off, MDI type is auto
Transceiver info:
Statistics:
5 minute input rate 2045 bits/sec, 2 packets/sec
5 minute output rate 17 bits/sec, 0 packets/sec
The last 5 second input rate 2048 bits/sec, 2 packets/sec
The last 5 second output rate 205 bits/sec, 0 packets/sec
Input packets statistics:
173021 input packets, 17313553 bytes, 0 no buffer
114992 unicast packets, 56940 multicast packets, 1089 broadcast packets
0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
0 abort, 0 length error, 0 pause frame
Output packets statistics:
114154 output packets, 20925992 bytes, 0 underruns
112975 unicast packets, 10 multicast packets, 1169 broadcast packets
0 output errors, 0 collisions, 0 late collisions, 0 pause frame
А вот на ХуаВее дело пошло никак
Делаю как в доках написано:
system-view
interface Eth-Trunk1
port link-type trunk
port trunk allow-pass vlan 10
mode lacp-static
max bandwidth-affected-linknumber 2
quit
interface GigabitEthernet0/0/1
eth-trunk 1
lacp priority 100
interface GigabitEthernet0/0/2
eth-trunk 1
lacp priority 100
Тоесть вроде бы все ок, должно работать. Но не тут то было.
Смотрю сюда
[TP-SW02]display port vlan Eth-Trunk 1
Port Link Type PVID Trunk VLAN List
Eth-Trunk1 trunk 1 1 10
И вот сюда
[TP-SW02]display eth-trunk 1
Eth-Trunk1's state information is:
Local:
LAG ID: 1 WorkingMode: STATIC
Preempt Delay: Disabled Hash arithmetic: According to SA-XOR-DA
System Priority: 100 System ID: 1011-1213-1415
Least Active-linknumber: 1 Max Active-linknumber: 8
Operate status: down Number Of Up Port In Trunk: 0
ActorPortName Status PortType PortPri PortNo PortKey PortState Weight
GigabitEthernet0/0/1 Unselect 1GE 100 1 305 10100010 1
GigabitEthernet0/0/2 Unselect 1GE 100 2 305 10100010 1
Partner:
ActorPortName SysPri SystemID PortPri PortNo PortKey PortState
GigabitEthernet0/0/1 0 0000-0000-0000 0 0 0 10100011
GigabitEthernet0/0/2 0 0000-0000-0000 0 0 0 10100011
и ничего не понимаю.
Поясните, что я делаю не так.
