Razdor0407
Новичок
  • Публикации
    2
  • Зарегистрирован
  • Посещение
О Razdor0407
  • Звание
    Абитуриент
  1. при загрузки терминала выводит следующие сообщения Decompress 5267249 byte. Please wait system up... Warning: Unit 0 Port ge0: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge1: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge2: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge3: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge4: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge5: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge6: Failed to set initial mode: Feature unavailable Warning: Unit 0 Port ge7: Failed to set initial mode: Feature unavailable а при выполнении команды show run Building configuration... Current configuration: ! !version 10.1.0B build 29333 service timestamps log date service timestamps debug date service password-encryption ! hostname Prigorodnoe-1 ! ! ! ! ! ! ! ! ! ! ! ip default-gateway 95.167.80.65 ! no spanning-tree spanning-tree bpdu-terminal ! ! ! ! ! ! aaa authentication login default local aaa authentication enable default none aaa authorization exec default local ! username admin password 7 1330455C244F ! ! interface GigaEthernet0/1 switchport pvid 30 ! interface GigaEthernet0/2 ! interface GigaEthernet0/3 ! interface GigaEthernet0/4 ! interface GigaEthernet0/5 ! interface GigaEthernet0/6 ! interface VLAN30 ip address 95.167.80.66 255.255.255.248 ! ! ! vlan 1,30,1008-1015,1101 ! ! ! ! ! ip http server ! ! ! ip sshd enable ! time-zone tz 8 0 sntp master 4 sntp server 95.167.80.7 ! ! !Pending configurations for absent linecards: ! !!slot 0 84 interface GigaEthernet0/1 switchport trunk vlan-allowed 30,1008-1015,1101 switchport trunk vlan-untagged none switchport mode trunk speed 1000 duplex full ! interface GigaEthernet0/2 switchport trunk vlan-allowed 30,1008-1015,1101 switchport trunk vlan-untagged none switchport mode trunk speed 1000 duplex full !
  2. Здравствуйте. Терминал GEPON BDCOM P3310. На него можно зайти только через консоль. При загрузке интерфейсы есть, но они не активны. Помогите советом. Можно ли его отремонтировать, если да то где это можно сделать.
