Конфигурация:
CRS326-24G-2S+
MikroTik RouterOS 6.40.4
Access Потры 3,4 Vlan101
Access Потры 5,6 Vlan106
sfp-sfpplus1 Trunk Vlan101,Vlan106
Vlan101 - 172.30.1.250/24
Vlan106 - 172.30.6.250/24
К порту 3 подключен ПК с адресом 172.30.1.17/24
За транком весит девайс с адресом 172.30.1.254/24
# jan/02/1970 06:55:25 by RouterOS 6.40.4
# software id = FMMD-IA41
# model = CRS326-24G-2S+
# serial number = 763C07FEB797
/interface ethernet
set [ find default-name=ether1 ] name=ether1-master
set [ find default-name=ether2 ] master-port=ether1-master
set [ find default-name=ether3 ] master-port=ether1-master
set [ find default-name=ether4 ] master-port=ether1-master
set [ find default-name=ether5 ] master-port=ether1-master
set [ find default-name=ether6 ] master-port=ether1-master
set [ find default-name=ether24 ] master-port=ether1-master
set [ find default-name=sfp-sfpplus1 ] master-port=ether1-master
set [ find default-name=sfp-sfpplus2 ] master-port=ether1-master
/interface vlan
add interface=ether1-master name=vlan101 vlan-id=101
add interface=ether1-master name=vlan106 vlan-id=106
/interface ethernet switch port
set 2 default-vlan-id=101 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=101 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=106 vlan-header=always-strip vlan-mode=secure
set 5 default-vlan-id=106 vlan-header=always-strip vlan-mode=secure
set 24 vlan-header=add-if-missing vlan-mode=secure
set 26 default-vlan-id=0 vlan-header=add-if-missing
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot
/interface ethernet switch vlan
add ports=switch1-cpu,ether3,ether4,sfp-sfpplus1 switch=switch1 vlan-id=101
add ports=switch1-cpu,ether5,ether6,sfp-sfpplus1 switch=switch1 vlan-id=106
/ip address
add address=172.30.1.250/24 interface=vlan101 network=172.30.1.0
add address=172.30.6.250/24 interface=vlan106 network=172.30.6.0
Проблема в том что переодически(5-10с) теряются пинги до шлюза
при этом с тойже периодичностью исчезает MAC у IP 172.30.1.17 на Vlan101 в ARP таблице.
В чем я ошибся?
