ShaManN
Пользователи-
Публикации
19 -
Зарегистрирован
Посещение
О ShaManN
Звание
Абитуриент
Небольшая задачка по настройке оборудования
тему ответил в ShaManN пользователя ShaManN в Активное оборудование Ethernet, IP, MPLS, SDN/NFV...
Я во всех этих вещах еще не так силен, так что на ваше компетентное мнение положусь! Switch#show logging Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) No Active Message Discriminator. No Inactive Message Discriminator. Console logging: level debugging, 13 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: disabled, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Persistent logging: disabled No active filter modules. ESM: 0 messages dropped Trap logging: level informational, 13 message lines logged и Switch#sh ip eigrp int IP-EIGRP interfaces for process 1 Xmit Queue Mean Pacing Time Multicast Pending Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes -
Вот команды в указанном порядке: 10.0.0.0/25 is subnetted, 1 subnets C 10.5.3.0 is directly connected, Vlan1 192.168.45.0/29 is subnetted, 1 subnets C 192.168.45.0 is directly connected, Vlan4 VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- 1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5 Fa0/6, Fa0/7, Fa0/8, Fa0/9 Fa0/10, Fa0/11, Fa0/12, Fa0/13 Fa0/14, Fa0/15, Fa0/16, Fa0/17 Fa0/18, Fa0/19, Fa0/20, Fa0/21 Fa0/22, Fa0/23, Fa0/24, Gig0/1 Gig0/2 4 VLAN0004 active Fa0/1 1002 fddi-default act/unsup 1003 token-ring-default act/unsup 1004 fddinet-default act/unsup 1005 trnet-default act/unsup VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2 ---- ----- ---------- ----- ------ ------ -------- ---- -------- ------ ------ 1 enet 100001 1500 - - - - - 0 0 4 enet 100004 1500 - - - - - 0 0 1002 fddi 101002 1500 - - - - - 0 0 1003 tr 101003 1500 - - - - - 0 0 1004 fdnet 101004 1500 - - - ieee - 0 0 1005 trnet 101005 1500 - - - ibm - 0 0 Vlan1 is up, line protocol is up Hardware is CPU Interface, address is 0090.21a1.5527 (bia 0090.21a1.5527) Internet address is 10.5.3.1/25 MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 21:40:21, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1682 packets input, 530955 bytes, 0 no buffer Received 0 broadcasts (0 IP multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 563859 packets output, 0 bytes, 0 underruns 0 output errors, 23 interface resets 0 output buffer failures, 0 output buffers swapped out Vlan4 is up, line protocol is up Hardware is CPU Interface, address is 0090.21a1.5527 (bia 0090.21a1.5527) Internet address is 192.168.45.1/29 MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 21:40:21, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1682 packets input, 530955 bytes, 0 no buffer Received 0 broadcasts (0 IP multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 563859 packets output, 0 bytes, 0 underruns 0 output errors, 23 interface resets 0 output buffer failures, 0 output buffers swapped out Tunnel1 is up, line protocol is down (disabled) Hardware is Tunnel Internet address is 192.168.46.1/30 MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation TUNNEL, loopback not set Keepalive not set Tunnel source (FastEthernet0/1), destination 192.168.45.2 Tunnel protocol/transport GRE/IP Key disabled, sequencing disabled Checksumming of packets disabled Tunnel TTL 255 Fast tunneling enabled Tunnel transport MTU 1476 bytes Tunnel transmit bandwidth 8000 (kbps) Tunnel receive bandwidth 8000 (kbps) Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out А вот на роутере на инт tu1 выдает line protocol is up: Router#sh int tu1 Tunnel1 is up, line protocol is up (connected) Hardware is Tunnel Internet address is 192.168.46.2/30 MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation TUNNEL, loopback not set Keepalive not set Tunnel source 192.168.45.2 (FastEthernet0/0), destination 192.168.45.1 Tunnel protocol/transport GRE/IP Key disabled, sequencing disabled Checksumming of packets disabled Tunnel TTL 255 Fast tunneling enabled Tunnel transport MTU 1476 bytes Tunnel transmit bandwidth 8000 (kbps) Tunnel receive bandwidth 8000 (kbps) Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out -
и так тыкался и сяк- не робит у меня. Кто скажет в чем подвох. loppback и ПК настроены -
Ок, и там посмотрим! applx, а что если на no passive-interface tu1 ругается? -
Уважаемые форумчане, помогите с решением данной задачки. Я конечно понимаю что это уже не ваш уровень и из разряда "для студента", но хотелось бы увидеть ваше решение.
Переход от меди к оптике
Подскажите еще железку чтоб базовые радиостанции(для раций) соединить с диспетчером через сеть SDH. Типа вот такого Мультисервисный мультиплексор СМК-30 -
Насчет остальных волокон не забыл;) Эти два варианта пока отправил инженерам глянуть и запросы на сайты тоже. Вот этот вариант похоже подходит. Но уверен что-нибудь в нем наверняка не устроит и альтернативные варианты тоже лишними не будут. Какие железки еще можно посмотреть? -
Теперь после беседы с инженерами задача упростилась.Участок трассы медной на ИКМ-7ТМ замещается на SDH. Это уже утверждено. Я про конвертеры в Е1 спрашивал для того чтобы речь с радиостанций передавать по сети SDH. Но это не проканало потому как управление еще нужно. Вопрос остался вот такой: Какая железка передавала бы переговоры с базовых радиостанций(по рациям) и управление по сети SDH? Диапазон до 200 Мгц. -
Теперь вопрос немного другого плана: Известны интерфейсы в ИКМ-7ТМ (RS-232-С, RS-485, v.35, v.36, x.21). Какая штуковина конвертирует потоки с них в Е1 ? Вот что в описании ИКМ-7ТМ написано: По возможности дайте ссылки на устройства или на сайты где такое есть -
Ок, этим поинтересуюсь. Мне так то по ДП надо было набрать варианты чтоб потом с более осведомленными людьми из них выбрать подходящее. -
Когерентные оптические системы связи
Меня именно кабельное интересовало. Вот, как раз это имел ввиду. А как такую штуку отличить от обычного WDM? -
Это вроде как проводная оптика с когерентным приемом -
Принцип работы, существующее оборудование, примеры реализации. Делимся кто что знает
С Вот это я хотел узнать. Значит такой вариант работает. Датчики передают инфу по меди, а радиоинтерфейсы чтоб антенны поставить и общаться по рации вдоль трубопровода. Откуда датчики кормятся для меня тайна)) Может как раз по ВЛ которая вдоль газопровода. С ДП вроде как прояснилось. -
Я в голове держу и думаю всем все понятно)) Газопровод проходящий по Башкирии(возьмем участок 500км). Вдоль него линия технологической связи построенная на ИКМ-7тм с радиоинтерфейсом: телемеханика, каналы АСУ, диспетчерская связь, ТФ. В общем куча датчиков вдоль трубы и с них информация собирается. Радиостанции по всей длине для общения осматривающих этот газопровод на расстоянии 30 км друг от друга(R=15км). Регенераторы ИКМ-7ТМ через 4-5км. Это то что работает сейчас. Эту линию надо модернизировать чтоб она работала на оптике и тоже со своим радиоинтерфейсом. Мне поставили задачу так, чтобы все работало на одном оптическом кабеле, без второго рядом проложенного кабеля для ДП. Т.е. ДП брать для каждой радиостанции, расположенной скажем через 40 км(или какой там радиус действия у современных радиостанций??) и регенераторов из каких то бесперебойных источников, которые можно найти/организовать вдоль газопровода. Как мне объяснили мол два кабеля-в два раза больше проблем. Предложили запитаться со станций катодной защиты (СКЗ). К ним подведено 220В. Расположены через 20-40км вдоль всего газопровода. Почему бы и нет? Но чем больше вариантов, тем лучше.Смотрю в инете схемы газопроводов,может еще какие источники есть...чет с этим беда. Нужен ваш дельный совет) Следующий этап будет какую сеть организовать при этом, какое оборудование...но то потом.
