Коллеги подскажите куда копать. Стоял себе OLT работал ни кого не трогал и вдруг решил что хватит. При включении горит power и мигает sys.
Подключился UART увидел следующее.
validate buffer 0x00002000 len 0x00076000
flash id: 0xffffffff
flash type not supported or flash not available
eth boot
ftp: err 2
image crc32 or len wrong
!!!failed. r�validate buffer 0x00002000 len 0x00076000
eth boot
image crc f64d5cce len 98f94
running image at 10000
SRAM Test Size 0x00200000 Start 0x000a8f48
SRAM Test Size Check Passed.
SRAM Test 8 Bit Byte R/W Passed.
SRAM Test 16 Bit Half-Word R/W Passed.
SRAM Test 32 Bit Word R/W Passed.
SRAM Test Passed.
to call post_stage3
DDR Test Started.
DDR Test Passed.
olt_aal_thread created
dba_thread created
olt_appl_thread created
olt_shell_thread created
logger thread created
Flash CTC OUI: 0x11 0x11 0x11
iROS OLT 3.10.28.33 Sep 29 2013 15:10:17
cmds:
h - show help
v - show version and iros information
v t - show threads debug info
v module test_number - asic verification
v aal - aal unit test
d m addr len - dump memory
d e addr len - dump eeprom
d p pool_id [0|1] - dump memory pool info.
flag 0 for all blocks. 1 for corrupted blocks only
d c - dump cpuload info.
b - dump/set by bytes
w - dump/set by words
s m addr val - set memory to value
s dis_mode - set mpcp discovery mode
s crc_mode - set mpcp crc8 mode
s f dst_port - set epon forwarding port
g addr - start execution at addr
p cpu - show cpu port
p onu - show onu status
p stats - show stats
p thread info - show thread info
p thread count - show thread count
p mdio device addr - show mdio
c stats - clear stats
c onu - clear onu
t arp port [bypass] - transmit arp frame
t oam port llid - transimit oam packet
t dereg port llid - deregister onu
m [level [mod]] - set logging level, default 7 for critical
k 0|1 - software watchdog timer enable 1; disable 0
olt->eeprom modes_and_oam_version = 0x0
Test bank 0xba3 row 0x0fff col 0x000 - 0x004
Write Pattern 0x55aa55aa
Verify Passed
Write Pattern 0xaa55aa55
Verify Passed
oam_isp_init g_isp_idx = 0
0000000b:7:19 cpuload calibration 855512
0000009d:7:18 EVENT: send control frame 0x172cb0
00000101:7:18 event_tx_start change the event Dest MAC
protocol=7, direction=2, action=1, forward_port=0x00000000
protocol=7, direction=1, action=1, forward_port=0x00000000
protocol=5, direction=2, action=7, forward_port=0x00000000
protocol=4, direction=2, action=7, forward_port=0x00000000
protocol=15, direction=2, action=3, forward_port=0x00000000
И все не реагирует на клавиатуру даже.
А еще подскажите правильные настройки под UART.
У меня такие 38400 8N1
