Andrey Savenkov Опубликовано 6 декабря, 2012 · Жалоба Ссылки на прошивки: S2940-8G - v7.0.3.1(R0058.0003); v7.0.3.5(R0217.0041) 7.0.3.5(R0217.0041) changelog: 7.0.3.5(R0217.0041) -------------------------------------------------------------- [69756] dhcp option 38 is not inserted to all dhcp Solicication packets 7.0.3.5(R0217.0020) -------------------------------------------------------------- [68698]DSCP/COS non-trust port [69159]DHCP snooping drops packets with option 80 [69430]IGMP join packets come back from port which send out 7.0.3.1(B0125.0002) -------------------------------------------------------------- [68730] savi block DHCPv6 packets 7.0.3.5(B0207.0001) -------------------------------------------------------------- [68816] ifAdminStatus OID ifOperStatus can not sparate [68786] It is impossible to remove trunk vlan from Port-Channel 7.0.3.1(B0082.0002) --------------------------------------------------------------- [65486] igmp snooping source and snooping can do together by mib S2940-8G-PoE - S2940-8G - v7.0.3.1(R0058.0003); v7.0.3.5(R0217.0041) 7.0.3.5(R0217.0041) changelog: 7.0.3.5(R0217.0041) -------------------------------------------------------------- [69756] dhcp option 38 is not inserted to all dhcp Solicication packets 7.0.3.5(R0217.0020) -------------------------------------------------------------- [68698]DSCP/COS non-trust port [69159]DHCP snooping drops packets with option 80 [69430]IGMP join packets come back from port which send out 7.0.3.1(B0125.0002) -------------------------------------------------------------- [68730] savi block DHCPv6 packets 7.0.3.5(B0207.0001) -------------------------------------------------------------- [68816] ifAdminStatus OID ifOperStatus can not sparate [68786] It is impossible to remove trunk vlan from Port-Channel 7.0.3.1(B0082.0002) --------------------------------------------------------------- [65486] igmp snooping source and snooping can do together by mib S2940-8G-v2 - v6.2.139.999, v7.0.3.1(R0002.0033), v7.0.3.5(R0217.002) S2950-24G - v7.0.3.1(R0058.003), v7.0.3.5(R0217.0041) 7.0.3.5(R0217.0041) changelog: 7.0.3.5(R0217.0041) -------------------------------------------------------------- [69756] dhcp option 38 is not inserted to all dhcp Solicication packets 7.0.3.5(R0217.0020) -------------------------------------------------------------- [68698]DSCP/COS non-trust port [69159]DHCP snooping drops packets with option 80 [69430]IGMP join packets come back from port which send out 7.0.3.1(B0125.0002) -------------------------------------------------------------- [68730] savi block DHCPv6 packets 7.0.3.5(B0207.0001) -------------------------------------------------------------- [68816] ifAdminStatus OID ifOperStatus can not sparate [68786] It is impossible to remove trunk vlan from Port-Channel 7.0.3.1(B0082.0002) --------------------------------------------------------------- [65486] igmp snooping source and snooping can do together by mib S2960-24G - v6.2.139.999, v7.0.3.1(R0002.0033), v7.0.3.5(R0217.002) S2960-48G - v6.2.141.12.zip, 6.2.141.17 v6.2.141.17 changelog: 6.2.141.17 changelog ------------------------------------------------------------- [70573] 60 symbols interface name length causes crash 6.2.141.11 changelog ------------------------------------------------------------- [70560] DHCPv6 drops DHCPv6 Solicication PD without IA_NA 6.2.141.8 changelog ------------------------------------------------------------- [69560] multicast traffic can not stop immediately 6.2.141.2 changelog -------------------------------------------------------------- [69220] SNR-S2960-48G 6.2.141.1 DHCP snooping drops packets with option 80 [69190] SSH does not work 6.2.141.1 changelog -------------------------------------------------------------- [69065] CPU_source_broadcast S2970G-24S (старая ревизия 20 SFP + 4 комбо) - v2.1.1A (Build 18662) S2970G-24S (новая ревизия 24 SFP + 4 комбо) - v2.1.1B S2970G-48S - v2.1.1A S2980G-24F - v7.0.3.1(R0058.0002), 7.0.3.5(b0207.0009) 7.0.3.5(b0207.0009) changelog --------------------------------------------------------------- [69669] some ports are used to across double tags and some are used to add tags when it enable dhcp snooping 7.0.3.5(B0207.0006) changelog --------------------------------------------------------------- [69337] DHCP snooping drops double-tagged frames containing DHCP requests, S2980-24F is not P device 7.0.3.5(B0207.0005) changelog -------------------------------------------------------------- [69056] DHCP snooping drops double-tagged frames containing DHCP requests 7.0.3.5(r0123.0011) changelog --------------------------------------------------------------- [67473] support DHCP snooping per vlan [68786] It is impossible to remove trunk vlan from Port-Channel S3650-24S - v6.2.200.200, v7.0.3.1(R0002.0033), 7.0.3.5(R0123.0011) S3650-48S - 7.0.3.5(R0123.0011) S3750-24S-E - v7.0.3.5(R0123.0011), v7.0.3.5(B207.0008) v7.0.3.5(B207.0008) changelog: 7.0.3.5(B0207.0008) changelog --------------------------------------------------- [69247]client can not get ip when enable super vlan + dhcp relay 7.0.3.5(R0123.0011) changelog --------------------------------------------------- [67473] support dhcp snooping per vlan Обращаем Ваше внимание, что присутствует задержка в выпуске прошивок для разных моделей коммутаторов! Обновление коммутаторов необходимо проводить последовательно согласно списку выше! Ссылки на документацию: S2940-8G - DataSheet, Configuration Guide, Command Guide, Installation Guide S2940-8G-v2 - DataSheet, Configuration Guide, Command Guide, Installation Guide S2950-24G - DataSheet, Configuration Guide, Command Guide, Installation Guide S2960-24G - DataShhet, Configuration Guide, Command Guide, Installation Guide S2960-48G - DataSheet, Configuration Guide, Command Guide, Installation Guide 2970G-24S - DataSheet, Configuration Guide, Command Guide, Installation Guide 2970G-48S - DataSheet, Configuration Guide Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
lumenok Опубликовано 17 декабря, 2012 · Жалоба Это полные changelog или лишь не большая часть? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
NikAlexAn Опубликовано 17 января, 2013 · Жалоба А какая версия boot.rom должна быть для последних прошивок? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
eill Опубликовано 18 января, 2013 · Жалоба NikAlexAn у меня используется 2.2.0 на s2950-24g, на s2960-24g стоит 4.22.1, а на s2960-48g используется 4.10.2. Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
dekalen Опубликовано 13 марта, 2013 · Жалоба Добрый день, имеем порядка 400 свитчей как на всех обновить прошивку? существует универсальное решение? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrey Savenkov Опубликовано 13 марта, 2013 · Жалоба Ну например по SNMP: Загрузка файлов с TFTP-сервера (Обновление ПО коммутатора) 1. Задаем IP-адрес TFTP-сервера: snmpset -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.10.3.0 s “y.y.y.y” 2. Задаем имя файла на TFTP-сервере: snmpset -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.10.4.0 s “6.2.138.103_nos.img” 3. Задаем имя файла на коммутаторе: snmpset -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.10.5.0 s “nos.img” 4. Устанавливаем тип сервера (1-FTP, 2-TFTP): snmpset -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.10.7.0 i 2 5. Запускаем процедуру загрузки (1-Upload, 2-Download): snmpset -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.10.8.0 i 2 Проверка статуса выполнения команды: snmpget -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.10.9.0 Результатом будет числовое значение текущего состояния: 0 - Error 1 - OK 2 - Uploading 3 - Downloading 4 - Idle Перезагрузка коммутатора: snmpset -v2c -c private x.x.x.x .1.3.6.1.4.1.6339.100.1.1.0 i 3 где: x.x.x.x - IP коммутатора Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
varney Опубликовано 25 марта, 2013 (изменено) · Жалоба boot-prom v4.22.1 обновил firmware с v6.2.138.103 на v6.2.139.118 итогом стало: что два снра презаписали прошиву и после перезагрузки перестали загружаться Recv total 5402186 bytes ..................................................................... Write ok. close tftp client. SNR-S2960-24G#reload Testing RAM... 0x04000000 RAM OK. Attaching to file system ... done. Loading flash:/nos.img ... Read primary img file error! инструкция по восстановлению ПО из boot меню не помогает. xmodem возвращает результат: File offset error. найденный ман по восстановлению По на 2970 не дает эффекта из-за отсутсвия возможности войти в режим монитора. как теперь быть? данный вопрос продублировал на support@nag.ru UPD. и не по теме, но наболело. а что за баг с записью конфига через write и copy running-config startup-config через ssh? при обычном врайтинге записывается дефаулт конфиг. при использовани врайт с консольного кабеля выдается два раза информационная строчка об удачной записи. при ссш, второго уведомления нет. думали что вылечится использованием copy running-config startup-config, но при выполнении бывает не успевает внести запись и в итоге так же уходит в дефолт. про write running-config гневного пока сказать ничего немогу. использовал пару раз и удачно. Изменено 26 марта, 2013 пользователем varney Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrey Savenkov Опубликовано 26 марта, 2013 · Жалоба varney - Прошивку от 2960-24G заливали? Для входа в бутром 2960-24G используйте комбинацию клавиш Ctrl+B (эта информация есть в документации) По поводу бага с write при коннекте по SSH - R&D занимается устранением данного бага, как только он будет устранен - будет выпущен новый билд прошивки, о чем будет сообщено в данной теме. Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
varney Опубликовано 26 марта, 2013 (изменено) · Жалоба 5391865 SNR-S2960-24G_6.2.139.118.zip __macosx 223 __MACOSX\._SNR-S2960-24G_6.2.139.118_nos.img 5402186 SNR-S2960-24G_6.2.139.118_nos.img ПО Ctrl+B в boot меню то я вхожу. иначе бы откуда я узнал о поддержке xmodem и что он приводит и результату: File offset error. Инструкиця по восстановлению ПО из boot-меню не помогает. Комп и свитч друг друга не видят. Пинг не проходит. Дайте ответ как их реанимировать. А то это были последние на складе до следующей поставки, па завтра их нужно было уже пустить в продакшен. UPD. Вспомнил. На первом свитче первоначальная прошивка удалась. И свитч после перезагрузки запустился. Но не был сохранен конфиг, т.е. свитч запустился с дефаулт конфигом. После настройки и перезагрузки уже не поднялся. На втором был сделан минимум настроек с сохранением (влан с айпи и указанием этого влана транком на интерфейс) и сразу же после прошивки не поднялся. Изменено 26 марта, 2013 пользователем varney Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrey Savenkov Опубликовано 26 марта, 2013 · Жалоба varney, по поводу прошивки отписал Вам в личку. Также прошу по возможности предоставить show tech и show run с коммутатора в момент, когда проявляется ошибка записи конфига. Это поможет собрать больше информации о баге и ускорить процесс его устранения Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
NikAlexAn Опубликовано 22 апреля, 2013 · Жалоба Вынужден повторить свой вопрос. Какая минимальная версия boot.rom должна быть для последних firmware для коммутаторов 2940-8g-v2 и 2960-24g ? Или это не важно? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrey Savenkov Опубликовано 22 апреля, 2013 · Жалоба Для данных моделей коммутаторов желательно иметь версию boot.rom не ниже 4.22.1 Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
NikAlexAn Опубликовано 23 апреля, 2013 · Жалоба Для данных моделей коммутаторов желательно иметь версию boot.rom не ниже 4.22.1 Может эту инфу в шапку и + ссылки на бутромы? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Harlequin Опубликовано 27 апреля, 2013 · Жалоба Какая версия прошивки используется в коммутаторах SNR-S2940-8G-POE? - та же, что для "обыкновенного" свитча SNR-S2940-8G? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
varney Опубликовано 17 мая, 2013 · Жалоба Прошивки версии 7.0 будут в ближайшее время размещены на data.nag.ru а когда? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrey Savenkov Опубликовано 30 мая, 2013 · Жалоба На данный момент прошивки версии 7.0 распространяются по запросу на support@nag.ru или ко мне в личку. В общий доступ прошивки будут выложены когда появятся для всех моделей коммутаторов. Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
namake Опубликовано 23 июня, 2013 · Жалоба На данный момент прошивки версии 7.0 распространяются по запросу на support@nag.ru или ко мне в личку. В общий доступ прошивки будут выложены когда появятся для всех моделей коммутаторов. хотелось бы увидеть changelog. Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
AlexTN Опубликовано 24 июня, 2013 · Жалоба Changelog в студию. Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
VVSina Опубликовано 24 июня, 2013 · Жалоба +1 Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
NikAlexAn Опубликовано 28 июня, 2013 · Жалоба Что хоть нового то в 7-ой версии? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Олег Кривицкий Опубликовано 29 июня, 2013 · Жалоба Что хоть нового то в 7-ой версии? Тормознутый ВЭБ интерфейс, нет проблем в новыми версиями SSH клиента Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
shicoy Опубликовано 30 июля, 2013 · Жалоба Что хоть нового то в 7-ой версии? Тормознутый ВЭБ интерфейс, нет проблем в новыми версиями SSH клиента И все? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MrNv Опубликовано 21 августа, 2013 · Жалоба есть что новее SoftWare Version 7.0.3.1(R0058.0002) для SNR-S3650G-48S ? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrey Savenkov Опубликовано 22 августа, 2013 · Жалоба На данный момент более свежих прошивок нет Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
[-Alt-] Опубликовано 9 сентября, 2013 · Жалоба Подскажите, где взять mib для 2960-24g, тот что на data.nag.ru не рабочий? Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
