Привет всем!
Может кто сталкивался с изменением IP адреса по SNMP на коммутаторе Huawei s2326.
В мануале нашел нужный oid .1.3.6.1.4.1.2011.5.25.41.1.2.1.1
так же в мануале помечено:
The entries in this table can be created. You can create the primary IP address, and then the secondary IP address on the interface. The newly-created IP address and mask cannot be the same as the existing ones.
Modification Restriction
After the IP address is created, the attribute of the IP address cannot be modified, because all the attributes of the IP address, except the row status, are closely associated with the IP address.
Currently, entries in hwIpAdEntIfIndex, hwIpAdEntNetMask, hwIpAdEntAddressType, and hwIfIpMethod can be created, but cannot be modified.
walk выдает вот что:
# snmpwalk -v2c -c testtest 172.22.137.142 SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.1.127.0.0.1 = IpAddress: 127.0.0.1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.1.172.22.137.142 = IpAddress: 172.22.137.142
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.2.127.0.0.1 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.2.172.22.137.142 = INTEGER: 36
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.3.127.0.0.1 = IpAddress: 255.0.0.0
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.3.172.22.137.142 = IpAddress: 255.255.255.240
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.4.127.0.0.1 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.4.172.22.137.142 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.5.127.0.0.1 = INTEGER: 65535
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.5.172.22.137.142 = INTEGER: 65535
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.6.127.0.0.1 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.6.172.22.137.142 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.7.127.0.0.1 = INTEGER: 4
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.7.172.22.137.142 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.8.127.0.0.1 = INTEGER: 1
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.8.172.22.137.142 = INTEGER: 1
Я так понял мне нужно создать новый набор оидов
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.1.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.2.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.3.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.4.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.5.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.6.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.7.172.22.140.70
SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.8.172.22.140.70
но как это сделать?
Пробовал выполнить:
snmpset -v2c -c testtest 172.22.137.142 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.1 a 172.22.140.70 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.2 i 36 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.3 a 255.255.255.240 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.4 i 1 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.5 i 65535 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.1.6 i 1 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.7 i 1 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.8 i 1
Error in packet.
Reason: noCreation (That table does not support row creation or that object can not ever be created)
Failed object: SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.1
или
snmpset -v2c -c testtest 172.22.137.142 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.1.172.22.140.70 a 172.22.140.70 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.2.172.22.140.70 i 36 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.3.172.22.140.70 a 255.255.255.240 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.4.172.22.140.70 i 1 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.5.172.22.140.70 i 65535 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.1.6.172.22.140.70 i 1 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.7.172.22.140.70 i 1 1.3.6.1.4.1.2011.5.25.41.1.2.1.1.8.172.22.140.70 i 1
Error in packet.
Reason: notWritable (That object does not support modification)
Failed object: SNMPv2-SMI::enterprises.2011.5.25.41.1.2.1.1.1.172.22.140.70
Если что софт V100R006C00SPC800
Заранее спасибо.
Изменено пользователем v.fedoseev
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Привет всем!
но как это сделать?
Пробовал выполнить:
Error in packet.
или
Error in packet.
Заранее спасибо.
Решил проблему самостоятельно.
Чтобы создать ip sub достаточно:
snmpset -v2c -c testtest 172.22.137.142 \
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.8.172.22.140.70 i 4 \
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.2.172.22.140.70 i 36 \
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.3.172.22.140.70 a 255.255.255.240 \
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.6.172.22.140.70 i 2
где:
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.8.172.22.140.70 hwIpAdEntAddrStatus ( 4 - createAndGo )
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.2.172.22.140.70 hwIpAdEntIfIndex
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.3.172.22.140.70 hwIpAdEntNetMask
.1.3.6.1.4.1.2011.5.25.41.1.2.1.1.6.172.22.140.70 hwIpAdEntAddressType ( 1 - primary , 2 - sub )
Остальные oid Read-only, поэтому ранее у меня ничего не получалось.
Ссылка на сообщение
Добрый день. Не подскажите какие еще могут быть пароли на boot room кроме стандартных?
BIOS LOADING ...
Copyright © 2008-2011 HUAWEI TECH CO., LTD.
(Ver149, Mar 15 2013, 11:02:25)
Ссылка на сообщение
Как отключить запись в logbuffer логгирование SNMPSET? Весь лог просто засран записями вида
%%01SNMP/4/SNMP_SET(l)[0]:MIB node set. (UserName=, SourceIP=, Version=v2c, RequestId=624549313, ErrorStatus=0, ErrorIndex=0, ..........)
Ссылка на сообщение
info-center source SNMP channel 4 log state off
Ссылка на сообщение
Подскажите от bootrom пароль какой ато обновился и стандартные не подходят
Ссылка на сообщение
Доброе ремя суток! Перестал работать S2300 (при включении горят все линки), при подключении через консоль выдает следующее:
BIOS LOADING .
   Register Contents when exception occur:
         sr = 0x00400002       cause = 0x00000010         epc = 0x80183468
   badVAdrs = 0x00000005          at = 0x00000000          v0 = 0x000000A5
         v1 = 0x801E2E87          a0 = 0x00000005          a1 = 0x00000FD8
         a2 = 0x00000013          a3 = 0x801D9984          t0 = 0x801E4E84
         t1 = 0x00000003          t2 = 0x801E2B6D          t3 = 0x801DAEE8
         t4 = 0x00000000          t5 = 0x00000000          t6 = 0x00000000
         t7 = 0x801F3568          t8 = 0x000009F8          t9 = 0x801F3568
         s0 = 0x00000005          s1 = 0x00000FD8          s2 = 0x00000002
         s3 = 0x00000003          s4 = 0x00000005          s5 = 0x00000005
         s6 = 0x801E4F1C          s7 = 0x00000005          k0 = 0x00000380
         k1 = 0x00000000          gp = 0x801E1E20          ra = 0x80183CE8
BIOS LOADING .
И так по кругу.
Есть шансы оживить его?
этот получилось полечить ?
Ссылка на сообщение
У всех коммутаторов на сети snmp индекс портов начинается с 5.
В один прекрасный момент на одном из коммутаторов индексы стали с 4 (Eth0/0/1 - 4, Eth0/0/2 - 5 и.т.д)
Причем аптайм был 120+ дней, конфиг не менялся.
Ребут не помог.
Как вправить ему мозги?
Ссылка на сообщение
http://forum.nag.ru/forum/index.php?showtopic=87313
отформатировать флеш, залить софт и патч, сохранить конфиг. после этого индексы перестроятся
Ссылка на сообщение
Снимать и везти в офис значит...
Не вариант, пусть так живет
Ссылка на сообщение
BIOS LOADING ...
Пишите, разлочу
Ссылка на сообщение
Попался экземпляр, интерфейс управления которого при непосредственном подключении через разные порты отвечает примерно на половину ICMP-запросов. По SNMP коммутатор при непосредственном подключении также теряется. При этом трафик через себя коммутатор пропускает без потерь на скорости 947 Мбит/c. Ни Format flash, ни Erase Flash проблемы не исправляют. Видимо какая-то аппаратная проблема. Кто-нибудь с таким сталкивался? Какая аппаратная неисправность может привести к такому поведению?
Изменено пользователем 0x05bc
Ссылка на сообщение
В порядке бреда.
Нога с чипа коммутации на cpu встала на полудуплекс с чьей-то стороны.
Перезалить/обновить прошивку?
Ссылка на сообщение
Добрый день.
Можете, пожалуйста, поделиться прошивкой и веб мордой. саппорт хуявея долго думает меня регистрировать...
Заранее спасибо.
Ссылка на сообщение
20 часов назад, salex940 сказал:
Добрый день.
Заранее спасибо.
Какая версия нужна?
Ссылка на сообщение
В 10.09.2017 в 15:52, MasterJey сказал:
Какая версия нужна?
Спасибо что откликнулись, зарегистрировался, курю мануалы.
Удачи!
Ссылка на сообщение
Создать учетную запись
Подписчики 0
