Здравствуйте Коллеги ,
Помогите разобраться с ситуацией.
Имеется SNR-S2985G-24T + DELL POWEREDGE R430 (netXtreme 530, 4-е интерфейса) + SINOLOGY 815RP+.
у SNR последняя прошивка с сайта
CPU Mac f8:f0:82:77:03:1d
 Vlan MAC f8:f0:82:77:03:1c
 SoftWare Version 7.0.3.5(R0241.0172)
 BootRom Version 7.2.25
 HardWare Version 1.0.2
 CPLD Version N/A
 Serial No.:SW067210H310000789
 Copyright (C) 2017 NAG LLC
 All rights reserved
 Last reboot is warm reset.
LACP на SNR настраивался по руководству http://data.nag.ru/SNR%20Switches/Configuration%20Guide/SNR-S2965_SNR-S2985G/01-Basic%20Management%20Configuration.pdf.
С Sinology проблем не возникло, объединил 4 порта (11-14).
SNR-S2985G-24T# config
SNR-S2985G-24T(config)# show port-group brief
ID: port group number;  Mode: port group mode such as on active or passive;
Ports: different types of port number of a port group,
      the first is selected ports number, the second is standby ports number, and
      the third is unselected ports number.
ID   Mode     Partner ID                  Ports       Load-balance
1    active   0x0000,00-00-00-00-00-00    0,3,0       dst-src-mac-ip
2    active   0xffff,00-11-32-73-be-0d    4,0,0       dst-src-mac-ip
SNR-S2985G-24T(config)# show port-group detail
Flags:  A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
       D -- Synchronization, E -- Collecting, F -- Distributing,
       G -- Defaulted, H -- Expired
Port-group number: 1,  Mode: active,   Load-balance: dst-src-mac-ip
Port-group detail information:
System ID: 0x000f,f8-f0-82-77-03-1d
Local:
 Port             Status      Priority  Oper-Key Flag
 Ethernet1/0/2    Standby     32768     1        {ACG}
 Ethernet1/0/3    Standby     32768     1        {ACG}
 Ethernet1/0/4    Standby     32768     1        {ACG}
Remote:
 Actor           Partner  Priority  Oper-Key SystemID                    Flag
 Ethernet1/0/2   0        0         0        0x8000,00-00-00-00-00-00    {CG}
 Ethernet1/0/3   0        0         0        0x8000,00-00-00-00-00-00    {CG}
 Ethernet1/0/4   0        0         0        0x8000,00-00-00-00-00-00    {CG}
Port-group number: 2,  Mode: active,   Load-balance: dst-src-mac-ip
Local:
 Ethernet1/0/11   Selected    32768     2        {ACDEF}
 Ethernet1/0/12   Selected    32768     2        {ACDEF}
 Ethernet1/0/13   Selected    32768     2        {ACDEF}
 Ethernet1/0/14   Selected    32768     2        {ACDEF}
Remote:
 Ethernet1/0/11  1        255       17       0xffff,00-11-32-73-be-0d    {ABCDEF}
 Ethernet1/0/12  2        255       17       0xffff,00-11-32-73-be-0d    {ABCDEF}
 Ethernet1/0/13  3        255       17       0xffff,00-11-32-73-be-0d    {ABCDEF}
 Ethernet1/0/14  4        255       17       0xffff,00-11-32-73-be-0d    {ABCDEF}
Проблема возникла с сервером, установлено ESXi 6.0 u3 (последняя), выделенные по LACP порты 2-4.
ESXi настраивается по IP hash в терминологии vmware.
Аналогичным образом сконфигурировал интерфейсы 2-4 на SNR.
Создал дополнительный свитч, назначил незанятые интерфейсы (3 шт.) https://yadi.sk/d/fJ6D6jRn3MATge
И как видно, на SNR порты находятся в ожидании.
SNR-S2985G-24T#show running-config
no service password-encryption
hostname SNR-S2985G-24T
sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia
sysContact support@nag.ru
username admin privilege 15 password 0 admin
username root privilege 15 password 0 root
username Admin password 0 superuser
authentication line console login local
ftp-server enable
ssh-server enable
vlan 1
load-balance dst-src-mac-ip
lacp system-priority 15
port-group 1
port-group 2
Interface Ethernet1/0/1
Interface Ethernet1/0/2
port-group 2 mode active
Interface Ethernet1/0/3
Interface Ethernet1/0/4
Interface Ethernet1/0/5
Interface Ethernet1/0/6
Interface Ethernet1/0/7
Interface Ethernet1/0/8
Interface Ethernet1/0/9
Interface Ethernet1/0/10
Interface Ethernet1/0/11
port-group 1 mode active
Interface Ethernet1/0/12
Interface Ethernet1/0/13
Interface Ethernet1/0/14
Interface Ethernet1/0/15
Interface Ethernet1/0/16
Interface Ethernet1/0/17
Interface Ethernet1/0/18
Interface Ethernet1/0/19
Interface Ethernet1/0/20
Interface Ethernet1/0/21
Interface Ethernet1/0/22
Interface Ethernet1/0/23
Interface Ethernet1/0/24
Interface Ethernet1/0/25
Interface Ethernet1/0/26
Interface Ethernet1/0/27
Interface Ethernet1/0/28
Interface Port-Channel1
Interface Port-Channel2
interface Vlan1
ip address 10.100.100.254 255.255.255.0
no login
captive-portal
end
Заранее спасибо.
Изменено пользователем Vladislav121
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Делайте mode on.
Note: LACP is only supported in vSphere 5.1, 5.5 and 6.0 with vSphere Distributed Switches and on the Cisco Nexus 1000V.
Ссылка на сообщение
Создать учетную запись
Подписчики 0
