Абсолютно новая OLT в логе:
Jul 17 21:31:34 %OLT: Config ONU on interface EPON0/1:1 failed for 4 times, must be something wrong with this ONU !
BDCOM™ P3310C Software, Version 10.1.0E Build 37276
ONU P1004C1 Software Version : 10.0.16A 1037
Current configuration:
!version 10.1.0E build 37276
service timestamps log date
service timestamps debug date
service password-encryption
logging buffered 4096
hostname olt2
port-protected 1
ip default-gateway 10.0.36.33
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username mo password 7 ***********
epon oam-version 1 0x21
epon oam-version 2 0x20
epon onu-config-template T1
cmd-sequence 1 epon onu port 1 ctc vlan mode tag 1501
cmd-sequence 2 epon onu port 2 ctc vlan mode tag 720
cmd-sequence 3 epon onu port 3 ctc mcst tag-stripe enable
cmd-sequence 4 epon onu port 3 ctc vlan mode tag 333
cmd-sequence 5 epon onu port 3 ctc mcst mc-vlan add 666
cmd-sequence 6 epon onu all-port loopback detect
!!slot 0 89
interface GigaEthernet0/1
description -- uplink:olt1,gi0/1 --
switchport trunk vlan-allowed 207,333,666,720,1501
switchport trunk vlan-untagged none
switchport mode trunk
switchport pvid 333
interface GigaEthernet0/2
shutdown
interface GigaEthernet0/3
shutdown
interface GigaEthernet0/4
shutdown
interface GigaEthernet0/5
shutdown
interface GigaEthernet0/6
shutdown
interface EPON0/1
epon onu-authen-method mac
epon pre-config-template T1 binded-onu-llid 1-64
epon bind-onu mac 8479.7364.6e83 1
switchport trunk vlan-allowed 333,666,720,1501
switchport protected 1
interface EPON0/1:1
interface EPON0/2
shutdown
interface EPON0/3
shutdown
interface EPON0/4
shutdown
!!slot end
interface VLAN207
ip address 10.0.36.51 255.255.255.224
vlan 207
name mgmt7
vlan 333
name iptv
vlan 666
name iptv_mcast
vlan 720
name voip
vlan 1501
name pppoe.prm59
vlan 1,207,333,666,720,1501
ip mcst enable
ip igmp-proxy enable
ip mcst mrouter interface GigaEthernet0/5
ip mcst mc-vlan 666 range 239.0.10.1 - 239.0.10.255
ip http server
snmp-server community 0 ******* RO
snmp-server community 0 ******* RW
banner message
text Disconnect IMMEDIATELY if you are not an authorized person !!!
text Contact information:
time-zone ekt 5 0
ntp query-interval 60
ntp server 198.18.16.1
!Pending configurations for absent linecards:
!No configurations pending global
ПРобовал точно работающую ONU из дома.
interface RxPower(dBm)
epon0/1:1 -18.0
ПРошу помощи коллег )))))
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Разобрался.
Кому интересно:
olt2_config_epon0/1#no epon bind-onu mac 8479.7364.6e83
olt2_config_epon0/1#Jul 18 15:26:56 %EPON-ONUDEREG: ONU 8479.7364.6e83 is deregistered on EPON0/1:1
Jul 18 15:26:57 SQLITE-CLEAR-CFG clear onu config failed, rc = 11, zErrMsg = database disk image is malformed
Directory of /:
1 tiger.blob <FILE> 2084324 THU APR 20 13:19:58 2017
2 startup-config <FILE> 2770 SUN JAN 04 13:38:02 1970
3 config.db <FILE> 136192 SUN JAN 04 13:38:05 1970
0 Switch.bin <FILE> 7426889 MON JUL 17 21:19:08 2017
free space 6422528
olt2.prm59#delete config.db
this file will be erased,are you sure?(y/n)y
после ребута:
olt2#sh running-config interface epon0/1:1
Building configuration...
interface EPON0/1:1
epon onu port 1 ctc vlan mode tag 1501 priority 0
epon onu port 2 ctc vlan mode tag 720 priority 0
epon onu port 3 ctc vlan mode tag 333 priority 0
epon onu port 1 loopback detect
epon onu port 2 loopback detect
epon onu port 3 loopback detect
epon onu port 4 loopback detect
olt2.prm59#sh mac address-table interface EPON0/1:1
Mac Address Table (Total 1)
Vlan Mac Address Type Ports
1501 5cf4.abcc.e609 DYNAMIC epon0/1:1
Ссылка на сообщение
Подписчики 0
