savio Опубликовано 6 марта, 2017 · Жалоба Добрый день Вопрос наверное ламерский, но уже второй день бьюсь как об стенку Вчера распаковал BDCOM P3310C Switch#show version BDCOM(tm) P3310C Software, Version 10.1.0E Build 36039 Copyright by Shanghai Baud Data Communication CO. LTD. Compiled: 2016-6-22 15:11:12 by SYS, Image text-base: 0x80008000 ROM: System Bootstrap, Version 0.4.1, Serial num:00316002640 System image file is "Switch.bin" hardware version:V1.0 (RISC) processor with 131072K bytes of memory, 16384K bytes of flash Base ethernet MAC Address: 84:79:73:5b:6a:dc snmp info: product_ID:294 system_ID:1.3.6.1.4.1.3320.1.294.0 Switch uptime is 0:00:24:12, The current time: 1970-1-1 0:24:11 Switch# Подключил через сплитер 1x8 ONU APU-700XL и почитав мануалы выполнил базовую конфигруацию Switch#show configuration !version 10.1.0E build 36039 service timestamps log date service timestamps debug date logging buffered 4096 ! port-protected 1 ! ip default-gateway 10.15.208.1 ! spanning-tree mode rstp ! aaa authentication login default local aaa authentication enable default none aaa authorization exec default local ! username admin password 0 admin ! ! epon oam-version 1 0x21 epon oam-version 2 0x20 epon onu-config-template ots cmd-sequence 1 epon onu all-port ctc vlan mode tag 1775 cmd-sequence 2 epon onu all-port loopback detect ! ! !!slot 0 89 interface GigaEthernet0/6 description UPLINK switchport trunk vlan-allowed 106,1775 switchport trunk vlan-untagged none switchport mode trunk ! interface EPON0/1 description test epon pre-config-template ots binded-onu-llid 1-64 epon bind-onu mac a0c6.ec07.6968 1 filter dhcp switchport trunk vlan-allowed 1775 switchport trunk vlan-untagged none switchport mode trunk no switchport protected ! interface EPON0/1:1 ! interface EPON0/2 shutdown switchport protected 1 ! interface EPON0/3 shutdown switchport protected 1 ! interface EPON0/4 shutdown switchport protected 1 ! !!slot end ! interface VLAN1775 ip address 10.15.208.49 255.255.255.0 ! vlan 106 name dhcp ! vlan 1775 name access ! vlan 1,106,1775 ! ip http server ! !Pending configurations for absent linecards: ! !No configurations pending global Switch# ONU регистрируется Switch#show running-config ... interface EPON0/1 description test epon pre-config-template ots binded-onu-llid 1-64 epon bind-onu mac a0c6.ec07.6968 1 filter dhcp switchport trunk vlan-allowed 1775 switchport trunk vlan-untagged none switchport mode trunk no switchport protected ! interface EPON0/1:1 epon onu port 1 ctc vlan mode tag 1775 priority 0 epon onu port 1 loopback detect ! Со стороны OLT включен коммутатор(10.15.208.1), в ONU включен ноутбук(10.15.208.100) Проблема: трафик через OLT с ноутбука к коммутатору не ходит Ноутбук пингует OLT(10.15.208.49) но не пингует коммутатор аналогично, коммутатор пингует OLT(10.15.208.49) но не пингует ноутбук Подскажите пожалуйста, куда копать? что я делаю не так? Спасибо Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
