Ошибка при импорте шаблона. Zabbix 2.2.5
mb_strlen() expects parameter 1 to be string, array given [conf.import.php:130 → CConfigurationImport->import() → CConfigurationImport->processDiscoveryRules() → CAPIObject->create() → CAPIObject->__call() → czbxrpc::call() → czbxrpc::callAPI() → call_user_func() → CDiscoveryRule->create() → CDiscoveryRule->createReal() → DB::insert() → DB::checkValueTypes() → zbx_strlen() → mb_strlen() in /usr/local/www/zabbix22/include/func.inc.php:955]
mysqli_real_escape_string() expects parameter 2 to be string, array given [conf.import.php:130 → CConfigurationImport->import() → CConfigurationImport->processDiscoveryRules() → CAPIObject->create() → CAPIObject->__call() → czbxrpc::call() → czbxrpc::callAPI() → call_user_func() → CDiscoveryRule->create() → CDiscoveryRule->createReal() → DB::insert() → DB::checkValueTypes() → zbx_dbstr() → mysqli_real_escape_string() in /usr/local/www/zabbix22/include/db.inc.php:1224]
Array to string conversion [conf.import.php:130 → CConfigurationImport->import() → CConfigurationImport->processDiscoveryRules() → CAPIObject->create() → CAPIObject->__call() → czbxrpc::call() → czbxrpc::callAPI() → call_user_func() → CDiscoveryRule->create() → CDiscoveryRule->createReal() → DB::insert() → implode() in /usr/local/www/zabbix22/include/classes/db/DB.php:450]
Error in query [iNSERT INTO items (name,type,snmp_community,snmp_oid,delay,status,snmpv3_contextname,snmpv3_securityname,snmpv3_securitylevel,snmpv3_authprotocol,snmpv3_authpassphrase,snmpv3_privprotocol,snmpv3_privpassphrase,delay_flex,params,ipmi_sensor,authtype,username,password,publickey,privatekey,port,filter,lifetime,description,key_,trapper_hosts,hostid,flags,value_type,data_type,interfaceid,itemid) VALUES ('Mounted filesystem discovery','0','','','3600','0','','','0','0','','0','','','','','0','','','','','',Array,'30','Discovery of file systems of different types as defined in global regular expression \"File systems for discovery\".','vfs.fs.discovery','','13178','1','4','0',NULL,'56042')] [unknown column 'Array' in 'field list']
Ошибка при выполнении SQL запроса "INSERT INTO items (name,type,snmp_community,snmp_oid,delay,status,snmpv3_contextname,snmpv3_securityname,snmpv3_securitylevel,snmpv3_authprotocol,snmpv3_authpassphrase,snmpv3_privprotocol,snmpv3_privpassphrase,delay_flex,params,ipmi_sensor,authtype,username,password,publickey,privatekey,port,filter,lifetime,description,key_,trapper_hosts,hostid,flags,value_type,data_type,interfaceid,itemid) VALUES ('Mounted filesystem discovery','0','','','3600','0','','','0','0','','0','','','','','0','','','','','',Array,'30','Discovery of file systems of different types as defined in global regular expression \"File systems for discovery\".','vfs.fs.discovery','','13178','1','4','0',NULL,'56042')".
Импорт
Кто знает в чем причина?
