JerryLutor
Пользователи-
Публикации
71 -
Зарегистрирован
Посещение
О JerryLutor
Звание
Абитуриент
Контакты
ICQ
Array
cisco 4500 high CPU
тему ответил в vovan-pmr пользователя JerryLutor в Активное оборудование Ethernet, IP, MPLS, SDN/NFV...
Помогите пожалуйста, появилась высокая закгрузка на cisco 4506 sh processes cpu sorted CPU utilization for five seconds: 77%/9%; one minute: 76%; five minutes: 76% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 58 14577394 98220970 148 56.95% 57.36% 56.60% 0 Cat4k Mgmt LoPri 57 1108249 4253103 260 4.23% 4.43% 4.40% 0 Cat4k Mgmt HiPri sh platform health K2CpuMan Review 30.00 65.81 30 15 100 500 161 153 92 439:35 K2AccelPacketMan: Tx 10.00 45.30 20 1 100 500 112 105 63 317:37 show platform cpu packet statistics Packets Dropped In Hardware By CPU Subport (txQueueNotAvail) CPU Subport TxQueue 0 TxQueue 1 TxQueue 2 TxQueue 3 ------------ --------------- --------------- --------------- --------------- 0 0 0 0 1323378 2 0 867 6584 0 6 0 0 0 49024645 RkiosSysPacketMan: Packet allocation failures: 0 Packet Buffer(Software Common) allocation failures: 0 Packet Buffer(Software ESMP) allocation failures: 0 Packet Buffer(Software EOBC) allocation failures: 0 Packet Buffer(Software SupToSup) allocation failures: 0 IOS Packet Buffer Wrapper allocation failures: 0 Packets Dropped In Processing Overall Total 5 sec avg 1 min avg 5 min avg 1 hour avg -------------------- --------- --------- --------- ---------- 105488 0 0 0 0 Packets Dropped In Processing by CPU event Event Total 5 sec avg 1 min avg 5 min avg 1 hour avg ----------------- -------------------- --------- --------- --------- ---------- Input Acl 100846 0 0 0 0 SA Miss 4641 0 0 0 0 Packets Dropped In Processing by Priority Priority Total 5 sec avg 1 min avg 5 min avg 1 hour avg ----------------- -------------------- --------- --------- --------- ---------- Normal 99638 0 0 0 0 Medium 4702 0 0 0 0 High 981 0 0 0 0 Crucial 168 0 0 0 0 Packets Dropped In Processing by Reason Reason Total 5 sec avg 1 min avg 5 min avg 1 hour avg ------------------ -------------------- --------- --------- --------- ---------- SrcAddrTableFilt 1110 0 0 0 0 STPDrop 3520 0 0 0 0 L2DstDrop 11 0 0 0 0 NoDstPorts 100847 0 0 0 0 Total packet queues 16 Packets Received by Packet Queue Queue Total 5 sec avg 1 min avg 5 min avg 1 hour avg ---------------------- --------------- --------- --------- --------- ---------- L2/L3Control 1367425 42 40 37 29 Host Learning 428986 1 0 0 0 L3 Fwd Low 815734677 72762 81504 68139 56185 L2 Fwd Low 6704765 252 271 245 294 L2 Fwd Low 6704765 252 271 245 294 L3 Rx Low 335852 1 0 0 0 Packets Dropped by Packet Queue Queue Total 5 sec avg 1 min avg 5 min avg 1 hour avg ---------------------- --------------- --------- --------- --------- ---------- Host Learning 3282 0 0 0 0 L3 Fwd Low 1684342 336 259 176 120 L3 Rx Low 196 0 0 0 0 Куда копать? -
dvblast
тему ответил в Alexander пользователя JerryLutor в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
Подскажите по работе с cam модулями в dvblast Выдает слудующее: debug: opening MMI session (4) debug: sending DisplayReply on session (4) debug: MMI title: Viaccess Conditional Access debug: MMI subtitle: Prompt Message debug: MMI bottom: Press 'OK' to confirm debug: MMI choice: You do not have the rights to debug: MMI choice: access the audio. Где ему нажать "Ок" нужно, если программа консольная? -
D-link DIR-300/NRU (RALINK RT-3050) Убил загрузчик(бут). Jtag recovery.
тему ответил в nikolet пользователя JerryLutor в Флейм и "пионерские" сети
ясно спс :( , остается или вариант найти программатор для wrgn23 или в мусорку, печально. -
Те ножки которые я отметил на рисунке и есть jtag rf3050f по даташиту, а у меня как раз с убитым загрузчиком dir300b1. -
Кто нибудь снимал чип rt3050f на dir 300b1? Если то можете отследить куда идут ножки которые помечены черным на рисунке во вложении. -
getstream
тему ответил в Mechanic пользователя JerryLutor в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
Вопрос по getstream a84 На родном форуме проскочила информация что в конфиге есть блок отвечающий за запись лог в файл, хотя в описании конфигурации нет упоминаний о нем. Если у кого то есть пример секции поделитесь пожалуйста. Спрашивали на родном форуме но там молчат. -
Viasat ukraine
тему ответил в JerryLutor пользователя JerryLutor в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
комсомолец, в том то и дело что работает нестабильно, часто виснут. Проверял рывков сигнала нету. А последний сильный ливень вообще показал страстности работы x800го, если включить тюнер при качестве сигнала менее 30% то сигнал падает до 18 в течении 2 минут. И чем на дольше выключить тюнер и потом включить, тем дольше держится сигнал. Тюнера не греются. Mechanic, для работы оскама нужен генератор boxid(короткий) из оригинального boxid, если у Вас есть поделитесь пожалуйста, т.к те то я находил генерируют не верный ключ. -
Viasat ukraine
Кто нибудь использует для Viasat ukraine(карты для операторов), тюнеры openbox x800? Интересуют вопросы стабильности. в последнее время виснуть стали чаще. И иногда намертво, так что только из розетки. Может у кого есть прошивки для этих тюнеров? Или посоветуйте нормальное, не дорогое альтернативное оборудование ( и где купить в Украине, в личку. ). Заранее спасибо. -
Viasat ukraine
карточка операторская, но пришла без тюнера и без профкама. станция на обычных тюнерах. -
Кто нибудь работал с ними? Интересует в плане тюнеров (замены на аналогичные), активации карт и их продления. Пришла карта без тюнера, как активировать? При звонке в тех поддержку просят данные тюнера которого нету. P.S: не для домашнего пользования, а для КТВ.
getstream
У кого нибудь получилось собрать getstream a84 под ubuntu 11.10 (ядро 3.0)? Пробовал по рекомендации с форума разработчика, результата нету. -
Настройка головной станции.
didandr, спасибо! Есть еще вопросик, что б не создавать еще одну тему спрошу тут. Кто как мониторит станцию аналогового ктв? Каким оборудованием, можно в личку, заранее спасибо! -
Собственно сабж. Есть аналоговая головная станция, настроена но есть пару вопросов: Какая разбежка(мощность) должна быть между диапазонами ((1-5)-(s1-s8)-(6-12) и т.д)? Какая разбежка(мощность) между каналами в диапазоне? Каналы в диапазоне должны быть по возрастающий (имеется ввиду мощность)? Спасибо.
getstream
Оффтоп Кто нибудь работал с нтв картами 040600 -
getstream
jommystorm, убери lnb-sharing yes; в конфиге и будет напряжение.
