lyric
Пользователи-
Публикации
4 -
Зарегистрирован
Посещение
О lyric
Звание
Абитуриент
Контакты
ICQ
Array
ipv4 аренда/продажа
тему ответил в skinny пользователя lyric в Телекомбиржа - Circuit Exchange
Интересует покупка (если цена привлекательная) или долгосрочная аренда /22 /23 /24 Жду предложения в личку -
getstream
тему ответил в Mechanic пользователя lyric в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
я выложил полный лог - с момента запуска sasc'а до выключения getstream'а во время работы getstream'а лог такой: Sep 11 16:33:00.250 CHANNEL: Tuning frontend Sep 11 16:33:00.259 CSA: Got command(1): I idx: 0 pid: 0 Sep 11 16:33:00.259 demux: Opened fd: 0=12 mode: 2 Sep 11 16:33:00.275 demux: Got command 44 (size: 28) Sep 11 16:33:00.284 demux: ioctl on (12) returned: 0 Sep 11 16:33:00.292 : DMX_SET_PES_FILTER(12): pid:0 in:FRONTEND out:TS_TAP type:OTHER flags: IMMEDIATE_START Sep 11 16:33:00.300 CHANNEL: Sending PID: 0 Sep 11 16:33:00.309 CHANNEL: Got Start! Sep 11 16:33:00.309 frontend: Got command 78 (size: 48) Sep 11 16:33:00.325 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.334 : FE_GET_EVENT(10) returned 0 Sep 11 16:33:00.342 frontend: Got command 78 (size: 48) Sep 11 16:33:00.350 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.359 : FE_GET_EVENT(10) returned 0 SIGNAL Sep 11 16:33:05.262 frontend: Got command 69 (size: 12) Sep 11 16:33:05.289 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.314 : FE_READ_STATUS(10): SIGNAL Sep 11 16:33:05.322 frontend: Got command 67 (size: 12) Sep 11 16:33:05.331 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.339 : FE_SET_VOLTAGE(10): 13 Sep 11 16:33:05.347 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:05.355 frontend: Got command 66 (size: 12) Sep 11 16:33:05.364 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.372 : FE_SET_TONE(10): ON Sep 11 16:33:05.380 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:05.389 frontend: Got command 76 (size: 44) Sep 11 16:33:05.397 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.405 : FE_SET_FRONTEND(10): freq: 1574000 inv: AUTO QPSK: sr: 4340000 fec: 9 Sep 11 16:33:05.414 CHANNEL: Tuning frontend Sep 11 16:33:05.422 CSA: Got command(1): I idx: 0 pid: 0 Sep 11 16:33:05.422 demux: Got command 42 (size: 12) Sep 11 16:33:05.439 demux: ioctl on (12) returned: 0 Sep 11 16:33:05.447 : DMX_STOP(12) Sep 11 16:33:05.455 demux: Got command 41 (size: 12) Sep 11 16:33:05.464 demux: ioctl on (12) returned: 0 Sep 11 16:33:05.472 : DMX_START(12) Sep 11 16:33:05.480 frontend: Got command 78 (size: 48) Sep 11 16:33:05.489 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.497 : FE_GET_EVENT(10) returned 0 -
getstream
Доброго времени суток! Пытаюсь настроить связку sasc-ng+getstream для вещания с НТВ+ c Eutelsat W4 (ключи с коммерческого шаринг-сервера), пока не получается. sasc-ng устанавливал по этому мануалу. В попытках заставить заработать пробовал: - изменить CWS_NETMSGSIZE=480 в newcamd.c - не удалять параметр -O3 в Makefile, как советуют в мануале (понятия не имею, за что он отвечает, честно говоря) getstream устанавливал обычно - apt-get install getstream $ uname -a Linux videosat01 2.6.32-5-686 #1 SMP Fri Sep 9 20:51:05 UTC 2011 i686 GNU/Linux Дистрибутив - Debian Squeeze В логах sasc-ng: Sep 11 16:32:42.286 : Version: 0.0.2-3d3aae2f843d+ Sep 11 16:32:42.318 : Could not setup device video: 0 != 1 Sep 11 16:32:42.329 CAM: initializing plugin: SoftCam (1.0.0pre-HG-3d3aae2f843d+): A software emulated CAM Sep 11 16:32:42.337 CAM(general.info): SC version 1.0.0pre-HG-3d3aae2f843d+ initializing (VDR 1.6.0) Sep 11 16:32:42.345 CAM: starting plugin: Sep 11 16:32:42.353 CAM(general.info): SC version 1.0.0pre-HG-3d3aae2f843d+ starting (VDR 1.6.0) Sep 11 16:32:42.362 CAM(core.load): ** Plugin config: Sep 11 16:32:42.370 CAM(core.load): ** Key updates (AU) are enabled (active CAIDs) (no prestart) Sep 11 16:32:42.378 CAM(core.load): ** Local systems DON'T take priority over cached remote Sep 11 16:32:42.387 CAM(core.load): ** Concurrent FF recordings are NOT allowed Sep 11 16:32:42.395 CAM(core.load): ** Force transfermode with digital audio Sep 11 16:32:42.403 CAM(core.load): ** ECM cache is set to enabled Sep 11 16:32:42.412 CAM(core.load): ** TsBufferSize is 4 MB Sep 11 16:32:42.420 CAM(core.load): ** ScCaps are 1 2 0 0 0 0 0 0 0 0 Sep 11 16:32:42.444 CAM(general.info): loading cardclient config from /etc/sc/cardclient.conf Sep 11 16:32:42.473 CAM(cardclient.newcamd): now using protocol version 525 (cdLen=8) Sep 11 16:32:42.487 CAM(cardclient.core): hostname=cserv4.net port=10000 emm=0 emmCaids 0500/ffff Sep 11 16:32:42.495 CAM(cardclient.core): Newcamd: username=тут_мой_логин password=тут_мой_пароль key=тут_ключ Sep 11 16:32:42.503 CAM(cardclient.core): client 'Newcamd' ready Sep 11 16:32:42.624 CAM(core.net): connecting to cserv4.net:10000/tcp (178.162.248.59) Sep 11 16:32:42.927 CAM(cardclient.login): Newcamd: CaID=0500 admin=0 srvUA=0000000000000000 provider 040600/0000000000000000 030600/0000000000000000 023700/0000000000000000 Sep 11 16:32:42.936 CAM(general.error): failed open /etc/sc/SoftCam.Key: No such file or directory Sep 11 16:32:42.945 CAM(general.error): failed open /etc/sc/smartcard.conf: No such file or directory Sep 11 16:32:42.953 CAM(general.error): failed open /etc/sc/cardslot.conf: No such file or directory Sep 11 16:32:42.961 CAM(general.error): failed open /etc/sc/override.conf: No such file or directory Sep 11 16:32:42.970 CAM(general.error): no keys loaded for softcam! Sep 11 16:32:42.978 CAM(core.load): ** registered systems: Sep 11 16:32:42.986 CAM(core.load): ** Cardclient (pri -15) Sep 11 16:32:42.995 CAM(core.load): ** Conax (pri -10) Sep 11 16:32:43.003 CAM(core.load): ** ConstCW (pri -20) Sep 11 16:32:43.011 CAM(core.load): ** Cryptoworks (pri -10) Sep 11 16:32:43.020 CAM(core.load): ** Irdeto (pri -10) Sep 11 16:32:43.028 CAM(core.load): ** Irdeto2 (pri -8) Sep 11 16:32:43.036 CAM(core.load): ** Nagra (pri -10) Sep 11 16:32:43.045 CAM(core.load): ** Nagra2 (pri -10) Sep 11 16:32:43.053 CAM(core.load): ** Fake-NDS (pri -12) Sep 11 16:32:43.061 CAM(core.load): ** SC-Conax (pri -5) Sep 11 16:32:43.070 CAM(core.load): ** SC-Cryptoworks (pri -5) Sep 11 16:32:43.078 CAM(core.load): ** SC-Irdeto (pri -5) Sep 11 16:32:43.086 CAM(core.load): ** SC-Nagra (pri -5) Sep 11 16:32:43.094 CAM(core.load): ** SC-Seca (pri -5) Sep 11 16:32:43.103 CAM(core.load): ** SC-Viaccess (pri -5) Sep 11 16:32:43.111 CAM(core.load): ** SC-VideoGuard2 (pri -5) Sep 11 16:32:43.119 CAM(core.load): ** Seca (pri -10) Sep 11 16:32:43.128 CAM(core.load): ** Viaccess (pri -10) Sep 11 16:32:44.137 frontend: Starting thread on /dev/dvb/adapter1/frontend1 The thread scheduling parameters indicate: policy = 0 priority = 0 Sep 11 16:32:44.138 dvr: Starting thread on /dev/dvb/adapter1/dvr1 The thread scheduling parameters indicate: policy = 1 priority = 99 Sep 11 16:32:44.138 demux: Starting thread on /dev/dvb/adapter1/demux1 The thread scheduling parameters indicate: policy = 0 priority = 0 Sep 11 16:32:44.169 : Listening on port 5456 Sep 11 16:33:00.086 frontend: Opened fd: 0=10 mode: 4002 Sep 11 16:33:00.100 frontend: Got command 61 (size: 176) Sep 11 16:33:00.108 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.149 : FE_GET_INFO(10): 'Conexant CX24123/CX24109' min:950000 max:2150000 step:1011 tol:5000 minsr:1000000 maxsr:45000000 tolsr:0 Sep 11 16:33:00.159 frontend: Got command 67 (size: 12) Sep 11 16:33:00.167 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.175 : FE_SET_VOLTAGE(10): 13 Sep 11 16:33:00.184 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:00.192 frontend: Got command 66 (size: 12) Sep 11 16:33:00.201 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.209 : FE_SET_TONE(10): ON Sep 11 16:33:00.217 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:00.226 frontend: Got command 76 (size: 44) Sep 11 16:33:00.234 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.242 : FE_SET_FRONTEND(10): freq: 1574000 inv: AUTO QPSK: sr: 4340000 fec: 9 Sep 11 16:33:00.250 CHANNEL: Tuning frontend Sep 11 16:33:00.259 CSA: Got command(1): I idx: 0 pid: 0 Sep 11 16:33:00.259 demux: Opened fd: 0=12 mode: 2 Sep 11 16:33:00.275 demux: Got command 44 (size: 28) Sep 11 16:33:00.284 demux: ioctl on (12) returned: 0 Sep 11 16:33:00.292 : DMX_SET_PES_FILTER(12): pid:0 in:FRONTEND out:TS_TAP type:OTHER flags: IMMEDIATE_START Sep 11 16:33:00.300 CHANNEL: Sending PID: 0 Sep 11 16:33:00.309 CHANNEL: Got Start! Sep 11 16:33:00.309 frontend: Got command 78 (size: 48) Sep 11 16:33:00.325 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.334 : FE_GET_EVENT(10) returned 0 Sep 11 16:33:00.342 frontend: Got command 78 (size: 48) Sep 11 16:33:00.350 frontend: ioctl on (10) returned: 0 Sep 11 16:33:00.359 : FE_GET_EVENT(10) returned 0 SIGNAL Sep 11 16:33:05.262 frontend: Got command 69 (size: 12) Sep 11 16:33:05.289 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.314 : FE_READ_STATUS(10): SIGNAL Sep 11 16:33:05.322 frontend: Got command 67 (size: 12) Sep 11 16:33:05.331 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.339 : FE_SET_VOLTAGE(10): 13 Sep 11 16:33:05.347 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:05.355 frontend: Got command 66 (size: 12) Sep 11 16:33:05.364 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.372 : FE_SET_TONE(10): ON Sep 11 16:33:05.380 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:05.389 frontend: Got command 76 (size: 44) Sep 11 16:33:05.397 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.405 : FE_SET_FRONTEND(10): freq: 1574000 inv: AUTO QPSK: sr: 4340000 fec: 9 Sep 11 16:33:05.414 CHANNEL: Tuning frontend Sep 11 16:33:05.422 CSA: Got command(1): I idx: 0 pid: 0 Sep 11 16:33:05.422 demux: Got command 42 (size: 12) Sep 11 16:33:05.439 demux: ioctl on (12) returned: 0 Sep 11 16:33:05.447 : DMX_STOP(12) Sep 11 16:33:05.455 demux: Got command 41 (size: 12) Sep 11 16:33:05.464 demux: ioctl on (12) returned: 0 Sep 11 16:33:05.472 : DMX_START(12) Sep 11 16:33:05.480 frontend: Got command 78 (size: 48) Sep 11 16:33:05.489 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.497 : FE_GET_EVENT(10) returned 0 SIGNAL Sep 11 16:33:05.505 frontend: Got command 78 (size: 48) Sep 11 16:33:05.514 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.522 : FE_GET_EVENT(10) returned 0 Sep 11 16:33:05.530 frontend: Got command 78 (size: 48) Sep 11 16:33:05.538 frontend: ioctl on (10) returned: 0 Sep 11 16:33:05.547 : FE_GET_EVENT(10) returned 0 Sep 11 16:33:10.262 frontend: Got command 67 (size: 12) Sep 11 16:33:10.277 frontend: ioctl on (10) returned: 0 Sep 11 16:33:10.294 : FE_SET_VOLTAGE(10): 13 Sep 11 16:33:10.302 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:10.310 frontend: Got command 66 (size: 12) Sep 11 16:33:10.319 frontend: ioctl on (10) returned: 0 Sep 11 16:33:10.327 : FE_SET_TONE(10): ON Sep 11 16:33:10.335 CHANNEL: Clearing tuning cache due to switch cmd Sep 11 16:33:10.344 frontend: Got command 76 (size: 44) Sep 11 16:33:10.352 frontend: ioctl on (10) returned: 0 Sep 11 16:33:10.360 : FE_SET_FRONTEND(10): freq: 1574000 inv: AUTO QPSK: sr: 4340000 fec: 9 Sep 11 16:33:10.369 CHANNEL: Tuning frontend Sep 11 16:33:10.377 CSA: Got command(1): I idx: 0 pid: 0 Sep 11 16:33:10.377 demux: Got command 42 (size: 12) Sep 11 16:33:10.422 demux: ioctl on (12) returned: 0 Sep 11 16:33:10.430 : DMX_STOP(12) Sep 11 16:33:10.439 demux: Got command 41 (size: 12) Sep 11 16:33:10.447 demux: ioctl on (12) returned: 0 Sep 11 16:33:10.455 : DMX_START(12) Sep 11 16:33:10.464 frontend: Got command 69 (size: 12) Sep 11 16:33:10.472 frontend: ioctl on (10) returned: 0 Sep 11 16:33:10.480 : FE_READ_STATUS(10): SIGNAL Sep 11 16:33:10.489 frontend: Got command 78 (size: 48) Sep 11 16:33:10.497 frontend: ioctl on (10) returned: 0 Sep 11 16:33:10.505 : FE_GET_EVENT(10) returned 0 getstream: $getstream -dc test_ntv.conf 2011-09-11 16:40:06.873 fe: Adapter 1 Setting up frontend tuner 2011-09-11 16:40:06.964 fe: DVB-S tone = 0 2011-09-11 16:40:06.964 fe: DVB-S voltage = 1 2011-09-11 16:40:06.964 fe: DVB-S diseqc = 0 2011-09-11 16:40:06.964 fe: DVB-S freq = 12418000 2011-09-11 16:40:06.964 fe: DVB-S lof1 = 10750000 2011-09-11 16:40:06.964 fe: DVB-S lof2 = 10750000 2011-09-11 16:40:06.964 fe: DVB-S slof = 11700000 2011-09-11 16:40:06.964 fe: DVB-S feparams.frequency = 1668000 2011-09-11 16:40:06.965 fe: DVB-S feparams.inversion = 2 2011-09-11 16:40:06.965 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000 2011-09-11 16:40:07.014 dmx: Setting filter for pid 0 pestype 20 2011-09-11 16:40:07.120 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) 2011-09-11 16:40:12.033 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) 2011-09-11 16:40:12.125 fe: DVB-S tone = 0 2011-09-11 16:40:12.125 fe: DVB-S voltage = 1 2011-09-11 16:40:12.125 fe: DVB-S diseqc = 0 2011-09-11 16:40:12.125 fe: DVB-S freq = 12418000 2011-09-11 16:40:12.125 fe: DVB-S lof1 = 10750000 2011-09-11 16:40:12.125 fe: DVB-S lof2 = 10750000 2011-09-11 16:40:12.125 fe: DVB-S slof = 11700000 2011-09-11 16:40:12.125 fe: DVB-S feparams.frequency = 1668000 2011-09-11 16:40:12.125 fe: DVB-S feparams.inversion = 2 2011-09-11 16:40:12.125 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000 2011-09-11 16:40:12.158 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter 2011-09-11 16:40:12.242 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) 2011-09-11 16:40:12.292 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) 2011-09-11 16:40:17.006 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter 2011-09-11 16:40:17.105 fe: DVB-S tone = 0 2011-09-11 16:40:17.105 fe: DVB-S voltage = 1 2011-09-11 16:40:17.105 fe: DVB-S diseqc = 0 2011-09-11 16:40:17.105 fe: DVB-S freq = 12418000 2011-09-11 16:40:17.105 fe: DVB-S lof1 = 10750000 2011-09-11 16:40:17.105 fe: DVB-S lof2 = 10750000 2011-09-11 16:40:17.105 fe: DVB-S slof = 11700000 2011-09-11 16:40:17.105 fe: DVB-S feparams.frequency = 1668000 2011-09-11 16:40:17.105 fe: DVB-S feparams.inversion = 2 2011-09-11 16:40:17.105 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000 2011-09-11 16:40:17.222 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) 2011-09-11 16:40:17.247 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) 2011-09-11 16:40:17.297 fe: Adapter 1 Status: 0x01 (HAS_SIGNAL) конфиг гетстрима: http{ port 8080; }; adapter 1 { packet-buffer 50; stat-interval 120; budget-mode 0; dvb-s { lnb { lof1 10750000; #Нижний предел lof2 10750000; #Верхний предел slof 11700000; #Частота переключения }; transponder { #описываем транспондер frequency 12418000; #Частота приема (указывали в scan.txt) polarisation h; #поляризация symbol-rate 27500000; #символьная скорость (указывали в scan.txt) }; }; #начало описания потока stream { name "RTR_Planeta_Ukraina"; #имя потока #входные данные потока input { pnr 10501; #pid пакета на спутнике }; #выходные данные для потока output-http { url /rtr_pu; #URL адрес, на который будет вещание }; }; }; В итоге VLC-клиент к серверу не конектится - бесконечно пытается открыть поток Буду очень благодарен, если натолкнете на мысль, куда копать дальше -
getstream
Пробую запустить связку getstream + opensasc-ng на debian lenny по мануалу http://dolot.kipdola.com/wiki/Install_SASC-NG затык на этапе mv sc_files/* /etc/camfiles/ у меня просто нет каталога sc_files... сейчас напрягаю гугл 2й час по этому вопросу - мб кто-нибудь подскажет для ускорения решения? заранее спасибо
