Здраствуйте, подскажите в какую сторону копать
есть каталист 6500 его конфиг :
ip vrf local_vrf
rd 1:1
ip multicast-routing
ip multicast-routing vrf local_vrf
vlan 309
name iptv_21210
vlan 310
name iptv_Ch13a
ip access-list standard sky_iptv
permit 239.255.1.0 0.0.0.255
permit 239.255.2.0 0.0.0.255
deny any
interface GigabitEthernet3/16
description servernaya2
switchport
switchport trunk encapsulation dot1q
switchport trunk native vlan 61
switchport trunk allowed vlan 50,61,310,554-556,560
switchport mode trunk
end
interface GigabitEthernet2/10
description servernaya3
switchport
switchport trunk allowed vlan 1,3,31,58,180,309,555
access-group mode prefer port
end
interface Vlan310
description Link_toMR2
ip vrf forwarding local_vrf
ip address 192.168.11.1 255.255.255.0
no ip redirects
no ip unreachables
ip pim sparse-mode
end
interface Vlan309
description source mcast
ip address 192.168.10.4 255.255.255.0
ip pim sparse-mode
ip sap listen
end
ip pim vrf local_vrf rp-address 192.168.10.4 sky_iptv override
в него включены клиентские свичи 2950 на них настроен MVR, все работает также в него в порт Gi3/16 включен раенный свич Catalyst 3550, его конфиг:
vlan 310
name Link_to_MR1
vlan 315
name house_iptv
interface GigabitEthernet0/8
description house
switchport protected
interface GigabitEthernet0/10
description Uplink
ip dhcp relay information trusted
ip dhcp snooping trust
interface Vlan310
description link_to_MR2
ip address 192.168.11.2 255.255.255.0
ip pim sparse-mode
interface Vlan315
description house iptv_vlan
ip address 192.168.16.1 255.255.255.0
ip pim sparse-mode
ip route 192.168.10.0 255.255.255.0 192.168.11.1
ip pim rp-address 192.168.10.4 sky_iptv override
#sh ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
P - Proxy Capable, S - State Refresh Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
192.168.11.1 Vlan310 01:14:13/00:01:17 v2 1 / S P
Simonenko#
ну а за етим маршрутизатором все както мутно работает, причем когда тестили то у чаловека через 5-10 мин только звук появился и на домовой циске вяло от него идут запросы.
Как можно продиагностировать в чем трабла?
еще вопрос в следующем, второй PIM должен маршруты сразу строить к источнику или по запросу igmp с дома?
MR2
#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.100), 22:24:17/00:02:42, RP 0.0.0.0, flags: SJC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan315, Forward/Sparse, 22:24:17/00:02:42
(*, 224.0.1.40), 1w0d/00:02:54, RP 0.0.0.0, flags: DCL
Vlan310, Forward/Sparse, 1w0d/00:02:54
на MR1
#sh ip mroute vrf local_vrf
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
(*, 239.255.1.17), 6d16h/stopped, RP 192.168.10.4, flags: SJC
Vlan309, Forward/Sparse, 6d16h/00:02:22
(192.168.10.2, 239.255.1.17), 6d16h/00:02:57, flags: PT
Incoming interface: Vlan309, RPF nbr 0.0.0.0, RPF-MFD
Outgoing interface list: Null
(*, 239.255.1.16), 6d16h/stopped, RP 192.168.10.4, flags: SJC
Vlan309, Forward/Sparse, 6d16h/00:02:28
(192.168.10.2, 239.255.1.16), 6d16h/00:02:57, flags: PT
