cyb3r_ang31
Пользователи-
Публикации
29 -
Зарегистрирован
Посещение
msd Lite - тестируем
тему ответил в Ivan_83 пользователя cyb3r_ang31 в Программное обеспечение, биллинг и *unix системы
Доброго времени суток. С недавних пор стал падать msd_lite каждый день примерно в одно и тоже время в ЧНН. В логах следующее: [2019-10-14 20:34:22] http_srv_new_conn_cb, line 892: error 9: Bad file descriptor client ip: 127.0.0.1:33266 ... [2019-10-14 20:34:23] http_srv_new_conn_cb, line 892: error 9: Bad file descriptor client ip: 127.0.0.1:33270 ... [2019-10-14 20:34:27] str_hub_create_int, line 510: io_task_notify_create() error 9: Bad file descriptor [2019-10-14 20:34:34]: Multi stream daemon lite 1.08: started [2019-10-14 20:34:34]: Build: Oct 25 2017 11:40:33, Release [2019-10-14 20:34:34]: CPU count: 16 [2019-10-14 20:34:34]: descriptor table size: 1024 (max files) [2019-10-14 20:34:34]: Thread 1 started... [2019-10-14 20:34:34]: Thread 3 started... [2019-10-14 20:34:34]: Bind thread 3 to CPU 3 [2019-10-14 20:34:34]: Bind thread 1 to CPU 1 [2019-10-14 20:34:34]: Thread 5 started... [2019-10-14 20:34:34]: Thread 4 started... [2019-10-14 20:34:34]: Thread 2 started... [2019-10-14 20:34:34]: Thread 10 started... [2019-10-14 20:34:34]: Thread 11 started... [2019-10-14 20:34:34]: Thread 7 started... [2019-10-14 20:34:34]: Thread 14 started... [2019-10-14 20:34:34]: Thread 8 started... [2019-10-14 20:34:34]: Bind thread 4 to CPU 4 [2019-10-14 20:34:34]: Thread 9 started... [2019-10-14 20:34:34]: Bind thread 2 to CPU 2 [2019-10-14 20:34:34]: Bind thread 9 to CPU 9 [2019-10-14 20:34:34]: Bind thread 5 to CPU 5 [2019-10-14 20:34:34]: Bind thread 10 to CPU 10 [2019-10-14 20:34:34]: Thread 12 started... [2019-10-14 20:34:34]: Thread 13 started... [2019-10-14 20:34:34]: Bind thread 11 to CPU 11 [2019-10-14 20:34:34]: Bind thread 12 to CPU 12 [2019-10-14 20:34:34]: Bind thread 7 to CPU 7 [2019-10-14 20:34:34]: Thread 15 started... [2019-10-14 20:34:34]: Bind thread 14 to CPU 14 [2019-10-14 20:34:34]: hostname: * [2019-10-14 20:34:34]: Thread 6 started... [2019-10-14 20:34:34]: Bind thread 8 to CPU 8 [2019-10-14 20:34:34]: Bind thread 6 to CPU 6 [2019-10-14 20:34:34]: bind 127.0.0.1:4022, backlog = 2048, cc_name = htcp [2019-10-14 20:34:34]: Thread 0 started... [2019-10-14 20:34:34]: Bind thread 13 to CPU 13 [2019-10-14 20:34:34]: Bind thread 0 to CPU 0 [2019-10-14 20:34:34]: Bind thread 15 to CPU 15 Подскажите где что посмотреть, судя по логам что то с дескрипторами файлов, но параметры max files, open files и тд везде увеличивать пробовали, не помогает. И почему descriptor table size: 1024 -
Авторизация по звонку
тему ответил в ShyLion пользователя cyb3r_ang31 в Программное обеспечение, биллинг и *unix системы
smsc.ru -
Syslog server для коммутаторов SNR
тему ответил в Voloda пользователя cyb3r_ang31 в Коммутаторы SNR, коммутаторы Orion Networks
graylog, loganalyzer -
Мегафоновская защита от DDoS - кто-нибудь пробовал?
тему ответил в alibek пользователя cyb3r_ang31 в Программное обеспечение, биллинг и *unix системы
Мы уже давно пробуем, вернее уже используем. После того как пошел DDoS на абонентские сети, а эффективность схемы с blackhole приближалась к нулю, подключили. Они на постоянку включают и гоняют весь ваш трафик через Периметр, который шлет на почту отчеты о начале и окончании атаки. -
cyb3r_ang31 подписался на Блокировка сайтов провайдерами
UTM 5 и уведомления
тему ответил в pagecom пользователя cyb3r_ang31 в Программное обеспечение, биллинг и *unix системы
Все конечно зависит от версии, но в последних точно есть в правилах firewall событие - Оповещение об изменении баланса. Работает так, задаете пороговое значение баланса, при прохождении которого вниз биллинг генерирует событие, которое через rfw можно обрабатывать как угодно. http://www.netup.ru/UTM5/documentation/billing-netup-utm-versiya-5.3-004/13-rfw_rus-3882/#XREF_i677991 -
тему ответил в a-zazell пользователя cyb3r_ang31 в Программное обеспечение, биллинг и *unix системы
А когда примерно планируется выложить версию extfilter, которая умеет собирать пакеты с маленьким win size? -
А как в extfilter победить проблему с vip-club-vulkan.net? -
UTM5 не разбирает трафик по пользователям
тему ответил в sergsa пользователя cyb3r_ang31 в Программное обеспечение, биллинг и *unix системы
Это глюк биллинга, который они признавать ни в какую не хотят. У нас такое случается с периодичностью раз в два-три месяца, помогает перезапуск ядра. Вендор забил на это, присылают отписки, что не могут повторить данный глюк у себя на тестовом стенде. -
Продается Extreme Summit X460-24X c 2бп, лицензия Edge, куплен в ноябре 2011 у НАГа, повреждений нет, все порты рабочие, без коробки. Ценник - 300тр, торг Располагается в Красноярском крае Пишите lexus@sibmf.ru
Пробовал уже и то и другое, ничего не помогает.
Дак понятное дело, что он включен. Порт работает, трафик через него ходит, но в SNMP его нет.
Уважаемые, подскажите пожалуйста! Имеем SE100 Redback Networks SmartEdge OS Version SEOS-11.1.2.6p4-Release На нем вот такие настройки snmp snmp server enhance ifmib snmp view monitor internet included snmp view monitor system included snmp view monitor interfaces included snmp view monitor snmp included snmp view monitor bgp included snmp view monitor ifMIB included snmp view monitor redBackNetworks included snmp view monitor ifEntry included snmp view monitor snmpEngine included snmp view monitor ifXEntry included snmp community public all-contexts view monitor snmp community public_border context border view monitor При этом при запросе списка портов snmpwalk -v2c -c public x.x.x.x .1.3.6.1.2.1.2.2.1.2 iso.3.6.1.2.1.2.2.1.2.1 = STRING: "port ethernet 1/1" iso.3.6.1.2.1.2.2.1.2.2 = STRING: "port ethernet 2/1" iso.3.6.1.2.1.2.2.1.2.3 = STRING: "port ethernet 2/2" iso.3.6.1.2.1.2.2.1.2.4 = STRING: "port ethernet 2/15" iso.3.6.1.2.1.2.2.1.2.5 = STRING: "port ethernet 2/3" iso.3.6.1.2.1.2.2.1.2.67108865 = STRING: "management" железяка не хочет показывать один физический порт 2/4, который при загрузке был выключен и включен уже в последствии. Как без перезагрузки железяки заставить показывать этот порт по snmp? Процесс snmp перезагружал, с настройками игрался, не помогает.
Опубликована Процедура блокировки некошерной инфо
тему ответил в Галушко Дмитрий пользователя cyb3r_ang31 в У нага
О чем вы говорите, наши контролирующие органы не всегда понимают, что они контролируют и как надо это контролировать, о каких DPI может вообще идти речь? -
Вот в том-то все и дело, что www.resistance88.com благополучно заблокирован и уже давно, а проверяли они www.resistance88.org, которого нет в списке, а вместо него есть www.resistanse88.com. И на каком основании по вашему я должен даже вручную блокировать www.resistance88.com, если его официально нет в списке минюста. А почему они тогда вместе с предписанием этот скриншот не предоставили? Полностью согласен. К Вам в дом не вломятся, а вот в какое-нить образовательное или государственное учреждение - всегда пожалуйста. -
В своих письмах прокуратура всегда ссылается на два пункта закона № 114-ФЗ: Обязанности нет, но оператора, как лицо способствующее распространению данной информации могут привлечь к ответственности. Чего они периодически и пытаются делать. Т.е. как всегда в наших законах, не обязан, но ответственен! И вот еще одни вопрос по теме: Законно ли проводить проверку на блокировку/доступность запрещенного сайта у абонента оператора без участия представителя этого оператора? Т.е. пришло нам предписание, что у нашего абонента есть доступ к запрещенной информации, а на сам процесс проверки нас никто не звал. И как они теперь докажут, что в момент проверки у абонента действительно был подключен наша линия и что запрещенный сайт действительно открылся?
