Повыходили 6.0.7 прошивки. Сделает кто-нибудь из них Compliance Test?
6.0.7 (XM/XW/TI) Changelog / September 8, 2017
Important:
airOS v6.0.7 will allow only signed firmware to be loaded. Signed versions of the following airOS versions are available: v5.6.15, v6.0.3, v6.0.4, v6.0.6
All future airOS versions will be signed in this way and not allow unsigned firmware to be loaded except via TFTP.
New:
- New: Add support for RFC 6598 (CGN) private IP responses via Discovery
- New: UNMS (Ubiquiti Networks Management System) support
- New: PPPoE LCP configuration via system.cfg
- New: Add Google Play and Appstore images on Login page
Fixes:
- Fix: Stability fixes (random XM series device reboots)
- Fix: TX reporting issues in Speed Test tool
- Fix: Duplicate RADIUS Accounting session ID
- Fix: Ignore server certificate validation on client side if CA not present
- Fix: Whitelist fixup_cfg_diff.txt file in persistent directory
- Fix: ATPC issue on SISO devices
- Fix: Removing WDS peer doesn't make an effect till AP reboot
- Fix: airView is broken
- Fix: AP-Repeater mode issues
- Fix: airOS security improvements
- WEB UI: Channel/Frequency reporting issue during scan on the Main Page
- WEB UI: DHCP Server Relay address does not show up after saving changes
- WEB UI: Connection issue to airGateway
