lockdoc
Новичок
  • Публикации
    2
  • Зарегистрирован
  • Посещение
Все публикации пользователя lockdoc
  1. У меня такая же проблема в город (FXO) можно звонить, из города нет. У меня такое устройство: cisco-2fxo#show version Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-IPVOICE-M), Version 12.3(23), RELEASE SOFTWARE (fc5) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by cisco Systems, Inc. Compiled Tue 24-Jul-07 14:47 by stshen Image text-base: 0x8000816C, data-base: 0x81455D6C ROM: System Bootstrap, Version 12.2(4r)XL, RELEASE SOFTWARE (fc1) cisco-2fxo uptime is 15 minutes System returned to ROM by reload at 12:05:11 Moscow Wed May 27 2015 System restarted at 12:07:15 Moscow Wed May 27 2015 System image file is "flash:c1700-ipvoice-mz.123-23.bin" cisco 1760 (MPC860P) processor (revision 0x200) with 59225K/6311K bytes of memory. Processor board ID FOC071218L4 (1906716500), with hardware revision BB67 MPC860P processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0. 1 Ethernet/IEEE 802.3 interface(s) 1 FastEthernet/IEEE 802.3 interface(s) 2 Voice FXO interface(s) 32K bytes of non-volatile configuration memory. 32768K bytes of processor board System flash (Read/Write) Configuration register is 0x2102 cisco-2fxo# Также после прочтения этой ветки форума переделал свой конфиг на следующий: cisco-2fxo#show running-config Building configuration... Current configuration : 2141 bytes ! ! No configuration change since last restart ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname cisco-2fxo ! boot-start-marker boot system flash:c1700-ipvoice-mz.123-23.bin boot system flash:c1700-sv3y-mz.123-26.bin boot-end-marker ! enable secret 5 $1$G2kC$.k32309gSDYcDmcwRXZYh. ! clock timezone Moscow 3 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 voice-card 1 ! no aaa new-model ip subnet-zero ip cef ! voice service pots ! voice service voip sip ! voice class codec 1 codec preference 1 g729r8 codec preference 2 g711alaw codec preference 3 g711ulaw ! voice class codec 2 codec preference 1 g711ulaw codec preference 2 g711alaw codec preference 3 g729r8 ! interface Ethernet0/0 no ip address shutdown half-duplex ! interface FastEthernet0/0 ip address dhcp hostname cisco-2fxo speed auto ! ip classless no ip http server ! voice-port 1/0 supervisory disconnect dualtone mid-call no non-linear no vad no comfort-noise cptone RU connection plar 551 impedance complex1 description tel 53-09-31 station-id name 53-09-31 caller-id enable ! voice-port 1/1 supervisory disconnect dualtone mid-call input gain 6 output attenuation 0 no comfort-noise cptone RU timeouts initial 30 timeouts call-disconnect 3 timeouts wait-release 10 connection plar 552 impedance complex1 description tel 53-93-00 station-id name 53-93-00 ! dial-peer voice 1 pots description tel 53-09-31 destination-pattern 703...... port 1/0 forward-digits 6 ! dial-peer voice 2 pots description tel 53-93-00 destination-pattern 704...... port 1/1 forward-digits 6 ! dial-peer voice 10 voip description all destination-pattern 55[12] voice-class codec 2 session protocol sipv2 session target sip-server session transport udp dtmf-relay rtp-nte no vad ! sip-ua sip-server ipv4:192.168.51.13:5060 ! ! line con 0 line aux 0 line vty 0 4 password 12345 login ! ntp clock-period 17208540 ntp server 195.2.64.6 ntp server 192.168.51.1 end cisco-2fxo# Астериск имеет следующий конфиг [703] type=friend host=192.168.51.14 qualify=yes qualifyfreq=10 disallow=all allow=ulaw allow=alaw context=main ;port=5060 nat=no insecury=port,invite [704] type=peer host=192.168.51.14 qualify=yes qualifyfreq=10 disallow=all allow=ulaw allow=alaw context=main nat=no insecury=port,invite Звоню в город по следующему экстеншену exten => _XXXXXX,1,Dial(SIP/192.168.51.14/703${EXTEN},60) exten => _XXXXXX,n,HangUp() Проблема в следующем: При звонке на FXO из города идет два гудка и занято. Звонки в город проходят нормально. Думаю второй день где накосячил?
