Alex24
Новичок
  • Публикации
    2
  • Зарегистрирован
  • Посещение
О Alex24
  • Звание
    Абитуриент
    Абитуриент
  1. =================================== Stage Ingress FP ================================ stageId = 0, sliceCount = 8, total rules num = 1024. ------------------------------------------------------------------------------------- slice 0:( 0) Single (dcn type 25) Protocol slice size = 128 SDK group id = 1 SDK entry total num = 56 1 - 2 5 - 6 9 11 13 - 17 23 - 24 27 29 - 30 33 - 34 37 - 38 41 43 45 47 - 48 51 - 52 55 - 56 59 - 60 63 65 - 68 73 75 77 79 81 - 83 87 - 92 99 101 103 - 104 107 109 141 ------------------------------------------------------------------------------------- slice 1:( 1) Single (dcn type 19) LPM slice size = 128 SDK group id = 2 SDK entry total num = 2 111 113 ------------------------------------------------------------------------------------- slice 2:( 2) Single (dcn type 28) IP-FW slice size = 128 SDK group id = 3 SDK entry total num = 13 0 0 0 0 0 0 0 0 0 0 0 0 135 ------------------------------------------------------------------------------------- slice 3:( 3) Single (dcn type 34) ing-vlan stat slice size = 128 SDK group id = 5 SDK entry total num = 3 146 - 148 ------------------------------------------------------------------------------------- slice 4:( 4) Single (dcn type 27) MAC-FW slice size = 128 SDK group id = 4 SDK entry total num = 3 157 - 159 ------------------------------------------------------------------------------------- slice 5:( 5) Single (dcn type 27) MAC-FW slice size = 128 SDK group id = 4 SDK entry total num = 3 157 - 159 ------------------------------------------------------------------------------------- slice 6:( 6) Single (dcn type 0) ARP-SCAN slice size = 128 SDK group id = 6 SDK entry total num = 2 152 154 ------------------------------------------------------------------------------------- slice 7: ------------------------------------------------------------------------------------- =================================== Stage Lookup FP ================================= stageId = 3, sliceCount = 4, total rules num = 0. ------------------------------------------------------------------------------------- slice 0: Err: Slice is NULL ------------------------------------------------------------------------------------- slice 1: ------------------------------------------------------------------------------------- slice 2: ------------------------------------------------------------------------------------- slice 3: ------------------------------------------------------------------------------------- the func return 0x0 На SNR-S2990-24T та же история. =================================== Stage Ingress FP ================================ stageId = 0, sliceCount = 8, total rules num = 1024. ------------------------------------------------------------------------------------- slice 0:( 0) Single (dcn type 25) Protocol slice size = 128 SDK group id = 1 SDK entry total num = 58 1 - 55 58 - 59 63 ------------------------------------------------------------------------------------- slice 1:( 1) Single (dcn type 19) LPM slice size = 128 SDK group id = 2 SDK entry total num = 2 56 - 57 ------------------------------------------------------------------------------------- slice 2:( 2) Single (dcn type 27) MAC-FW slice size = 128 SDK group id = 3 SDK entry total num = 9 60 - 62 64 - 69 ------------------------------------------------------------------------------------- slice 3:( 3) Single (dcn type 27) MAC-FW slice size = 128 SDK group id = 3 SDK entry total num = 9 60 - 62 64 - 69 ------------------------------------------------------------------------------------- slice 4:( 4) Single (dcn type 34) ing-vlan stat slice size = 128 SDK group id = 4 SDK entry total num = 3 70 - 72 ------------------------------------------------------------------------------------- slice 5:( 5) Single (dcn type 0) ARP-SCAN slice size = 128 SDK group id = 5 SDK entry total num = 2 73 - 74 ------------------------------------------------------------------------------------- slice 6:( 6) Single (dcn type 28) IP-FW slice size = 128 SDK group id = 6 SDK entry total num = 10 75 - 84 ------------------------------------------------------------------------------------- slice 7: ------------------------------------------------------------------------------------- =================================== Stage Lookup FP ================================= stageId = 3, sliceCount = 4, total rules num = 0. ------------------------------------------------------------------------------------- slice 0: Err: Slice is NULL ------------------------------------------------------------------------------------- slice 1: ------------------------------------------------------------------------------------- slice 2: ------------------------------------------------------------------------------------- slice 3: ------------------------------------------------------------------------------------- the func return 0x0
  2. Зравствуйте! CPU Mac f8:f0:82:73:49:f6 Vlan MAC f8:f0:82:73:49:f5 SoftWare Version 7.0.3.5(R0102.0182) BootRom Version 7.1.40 HardWare Version R01 CPLD Version N/A Serial No.:SW041610E820000092 Copyright © 2016 NAG LLC All rights reserved Last reboot is cold reset. Uptime is 2 weeks, 6 days, 22 hours, 11 minutes Проблема с ipv6 ipv6 access-list 600 deny any-source any-destination SNR-S2990G-48T-PVK#conf t SNR-S2990G-48T-PVK(config)#int eth1/0/30 SNR-S2990G-48T-PVK(config-if-ethernet1/0/30)#ipv6 access-group 600 in WARNING: No resource to bind access-list [600] to interface Ethernet1/0/30! SNR-S2990G-48T-PVK(config-if-ethernet1/0/30)# ipv6 access-list extended vacl_a6 deny any-source any-destination exit SNR-S2990G-48T-PVK(config)#vacl ipv6 access-group vacl_a6 in vlan 801 WARNING: No resource to apply acl vacl_a6 to ingress vlan 801! SNR-S2990G-48T-PVK(config)# на том же vlan висит vacl ipv4. Если его убрать, все то же самое
