Друзья, поставил домой Mikrotik hAP lite и упёрся в настройку IPTV. IPTV смотрю в через wifi на ТВ Samsung ( через PeersTV), иногда, на ноуте (тоже через вайфай). Картинка появляется, но сыпется безбожно и подвисает. Через богомерзкий dlink dir 300 таких проблем не появлялось.
Включил wmm-support=enabled и multicast-helper=full.
Подскажите, плиз, куда копать.
# aug/24/2017 20:55:56 by RouterOS 6.40.1
# software id =
# model = RouterBOARD 941-2nD
# serial number =
/interface bridge
add name=bridge-local
/interface ethernet
set [ find default-name=ether1 ] comment=WAN name=ethet1
set [ find default-name=ether2 ] name=ethet2
set [ find default-name=ether3 ] master-port=ethet2
set [ find default-name=ether4 ] master-port=ethet2
/interface wireless security-profiles
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=profile1 supplicant-identity="" \
wpa-pre-shared-key=****** wpa2-pre-shared-key=******
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
default-forwarding=no disabled=no mode=ap-bridge multicast-helper=full \
security-profile=profile1 wmm-support=enabled
/ip pool
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.20
/ip dhcp-server
add address-pool=dhcp_pool0 disabled=no interface=bridge-local name=dhcp1
/interface bridge port
add bridge=bridge-local interface=ethet2
add bridge=bridge-local interface=wlan1
/ip address
add address=192.168.88.1/24 interface=bridge-local network=192.168.88.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ethet1
/ip dhcp-server network
add address=192.168.88.0/24 gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes
/ip firewall filter
add action=accept chain=input comment="Allow IGMP" in-interface=ethet1 protocol=igmp
add action=accept chain=input comment="IPTV UDP incoming" dst-port=1234 in-interface=ethet1 protocol=udp
add action=accept chain=forward comment="IPTV UDP forwarding" dst-port=1234 in-interface=ethet1 protocol=udp
/ip firewall nat
add action=masquerade chain=srcnat out-interface=ethet1
/ip route
add distance=1 gateway=10.21.22.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/routing igmp-proxy
set query-interval=1s query-response-interval=1s quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=ethet1 upstream=yes
add interface=bridge-local
/system clock
set time-zone-name=Europe/Moscow
/system ntp client
set enabled=yes primary-ntp=195.151.98.66 secondary-ntp=80.240.216.155
#error exporting /system routerboard mode-button
