26.10.2009, 18:30
Сообщение
#1
Абитуриент Сообщений: 26 |
Задача: Научиться принимать и ретранслировать DVB-S2 потоки в сеть.
Для этого есть компьютер с: Карточка TT-3200 Дебиан 2.6.30-2-686 Тарелка Intelsat 904 at 60.0°E Транспондер 11675 V tp 68 DVB-S2 SR 29700 FEC 2/3 Строка запуска: ./dvblast -c s2.conf -a 0 -f 11675000 -s 29700000 -m psk_8 -u Содержимое s2.conf : 239.64.64.108:1234 1 1108 308,408 Все настраиваю, запускаю .. поток идет, но картинка вся ломаная ... В основном серый фон и какие-то очертания каких-то картинок видно ... Звука нет. Код test:/usr/src/dvblast# ./dvblast.sh warning: restarting debug: frequency 11675000 is in Ku-band (lower) debug: tuning QPSK frontend to f=11675000 srate=29700000 v=13 p=0 modulation=psk_8 debug: CA interface with 1 slot debug: CI link layer level interface type debug: 0 available descramblers (keys) debug: setting filter on PID 8192 debug: conf: 239.64.64.108:1234 w=1 sid=1108 pids[2]=308,408,-1,-1,-1... debug: frontend has acquired carrier debug: frontend has acquired sync debug: frontend has acquired lock debug: - Bit error rate: 0 debug: - Signal strength: 1450 debug: - SNR: 38 debug: en50221_Poll: slot 0 is active warning: discontinuity for PID 329 warning: discontinuity for PID 350 warning: discontinuity for PID 351 warning: discontinuity for PID 394 warning: discontinuity for PID 327 warning: discontinuity for PID 349 warning: discontinuity for PID 328 warning: discontinuity for PID 343 warning: discontinuity for PID 341 warning: discontinuity for PID 352 warning: discontinuity for PID 326 warning: discontinuity for PID 337 warning: discontinuity for PID 330 warning: discontinuity for PID 338 warning: discontinuity for PID 395 warning: discontinuity for PID 332 warning: discontinuity for PID 325 warning: transport_error_indicator warning: discontinuity for PID 337 .... warning: discontinuity for PID 345 warning: discontinuity for PID 394 warning: discontinuity for PID 327 warning: discontinuity for PID 329 warning: discontinuity for PID 337 libdvbpsi error (PSI decoder): TS discontinuity (received 7, expected 0) for PID 0 debug: new PAT ts_id=2 version=20 current_next=1 debug: * number=0 pid=16 debug: * number=1108 pid=43 debug: * number=1110 pid=33 debug: * number=1125 pid=49 debug: * number=1126 pid=40 debug: * number=1127 pid=41 debug: * number=1128 pid=47 debug: * number=1129 pid=76 debug: * number=1130 pid=73 debug: * number=1132 pid=38 debug: * number=1133 pid=39 debug: * number=1134 pid=70 debug: * number=1135 pid=46 debug: * number=1136 pid=45 debug: * number=1137 pid=51 debug: * number=1138 pid=44 debug: * number=1140 pid=91 debug: * number=1141 pid=57 debug: * number=1142 pid=63 debug: * number=1143 pid=58 debug: * number=1145 pid=53 debug: * number=1146 pid=59 debug: * number=1147 pid=55 debug: * number=1149 pid=54 debug: * number=1150 pid=56 debug: * number=1151 pid=61 debug: * number=1152 pid=60 debug: * number=1153 pid=62 debug: * number=1394 pid=37 debug: * number=1395 pid=42 debug: * number=1590 pid=32 debug: * number=4434 pid=98 debug: * number=4435 pid=97 debug: * number=4437 pid=36 debug: * number=4439 pid=35 debug: * number=4441 pid=34 warning: discontinuity for PID 347 warning: discontinuity for PID 445 ... warning: discontinuity for PID 332 warning: discontinuity for PID 338 libdvbpsi error (PSI decoder): TS discontinuity (received 9, expected 0) for PID 43 debug: new PMT program number=1108 version=4 pid_pcr=308 debug: * es pid=308 type=27 debug: * es pid=408 type=15 debug: * es pid=601 type=13 debug: * es pid=708 type=15 warning: discontinuity for PID 352 warning: discontinuity for PID 394 warning: discontinuity for PID 329 .... И много-много вот таких строчек warning: discontinuity for PID 352 warning: discontinuity for PID 394 warning: discontinuity for PID 329 warning: discontinuity for PID 352 warning: discontinuity for PID 394 warning: discontinuity for PID 329 Также пробывал mumudvb ... вроде все хорошо, но картинка такая же "ломанная" Смотреть пытаюсь в VLC 1.0.2. Кто-нибудь пробывал слать в сеть DVB-S2 ? |
28.10.2009, 16:36
Сообщение
#2
Вот ссылка на дамп потока
Поток DVB-S2 8PSK MPEG-4 с W4 36°, 12360 R Дампил открытый поток канала ЧП Инфо. Дамп снимался следующим образом w4.channel : Код Avtomotive:11727:hS0:S0.0W:27500:103:203:0:0:3:112:5:0 Discovery;HTB+:12456:hS0:S0.0W:27500:320:400=rus,401=eng:0:0:20501:112:5:0 1kanal:12418:hS0:S0.0W:27500:321:401:0:0:10501:112:5:0 ChP_Info:12360:vS0:S0.0W:27500:152:252:0:0:752:112:5:0 szap-s2 -l 10750 -S 1 -M 5 -H -c ./w4.channel -n 4 Код test:/usr/src/szap-s2# ./szap-s2 -l 10750 -S 1 -M 5 -H -c ./w4.channel -n 4 reading channels from file './w4.channel' zapping to 4 'ChP_Info': delivery DVB-S2, modulation 8PSK sat 0, frequency 12360 MHz V, symbolrate 27500000, coderate auto, rolloff 0.35 vpid 0x0098, apid 0x00fc, sid 0x0000 using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0' status 1a | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 260352955 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 43355136 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 2021802 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 226352955 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 226352955 | unc -2 | FE_HAS_LOCK status 1a | signal 2% | snr 0% | ber 253019622 | unc -2 | FE_HAS_LOCK dvbstream -f 12360000 -p V -s 27500 Код test:/usr/src# dvbstream -f 12360000 -p V -s 27500 152 252 -o > /usr/s2free.mpg dvbstream v0.6 - (C) Dave Chapman 2001-2004 Released under the GPL. Latest version available from http://www.linuxstb.org/ FRONTEND DEVICE: : Device or resource busy Tuning to 12360000 Hz FE_GET_INFO: : Bad file descriptor dvbstream will stop after -1 seconds (71582788 minutes) Output to stdout Streaming 2 streams http://ifolder.ru/14714554 |
29.10.2009, 0:56
Сообщение
#3
Абитуриент Сообщений: 33 |
29.10.2009, 1:39
Сообщение
#4
Абитуриент Сообщений: 32 |
Задача: Научиться принимать и ретранслировать DVB-S2 потоки в сеть. Для этого есть компьютер с: Карточка TT-3200 Дебиан 2.6.30-2-686 Тарелка Intelsat 904 at 60.0°E Транспондер 11675 V tp 68 DVB-S2 SR 29700 FEC 2/3 Строка запуска: ./dvblast -c s2.conf -a 0 -f 11675000 -s 29700000 -m psk_8 -u Содержимое s2.conf : 239.64.64.108:1234 1 1108 308,408 Все настраиваю, запускаю .. поток идет, но картинка вся ломаная ... В основном серый фон и какие-то очертания каких-то картинок видно ... Звука нет. Код test:/usr/src/dvblast# ./dvblast.sh warning: restarting debug: frequency 11675000 is in Ku-band (lower) debug: tuning QPSK frontend to f=11675000 srate=29700000 v=13 p=0 modulation=psk_8 debug: CA interface with 1 slot Также пробывал mumudvb ... вроде все хорошо, но картинка такая же "ломанная" Смотреть пытаюсь в VLC 1.0.2. Кто-нибудь пробывал слать в сеть DVB-S2 ? Попробуй в строке запуска поменять -u на -U, не забудь указать поляризацию |
29.10.2009, 12:39
Сообщение
#5
Попробуй в строке запуска поменять -u на -U, не забудь указать поляризацию Уже пробывал, результат тот же. Слишком слабый сигнал со спутника. Подкрути тарелку. Ресивер с этой-же тарелки принимает сигнал вообще без проблем, при этом его встроеный показометр показывает приличный уровень сигнала. |
29.10.2009, 13:56
Сообщение
#6
Что касается DVBlast, то меня смущает надпись
Код debug: tuning [b]QPSK[/b] frontend to f=11675000 srate=29700000 v=13 p=0 modulation=psk_8 как я понимаю там должно быть написанно 8PSK ... Сообщение отредактировал Kompik - 29.10.2009, 13:56 |
13.11.2009, 16:23
Сообщение
#7
Продублирую свое сообщение из соседней ветки :)
УРА ТОВАРИЩИ!!! Решил проблему! Все оказалось проще. Я думал что в кернеле 2.6.30 используются драйвера от Игоря Леплянинова (s2-liplianin) Но это оказалось роковой ошибкой! После установки драйверов от Игоря, szap-s2 стал выводит следующее: reading channels from file './channels.conf' zapping to 2 'TDK': delivery DVB-S2, modulation 8PSK sat 0, frequency 11675 MHz V, symbolrate 29700000, coderate auto, rolloff 0.35 vpid 0x0134, apid 0x0198, sid 0x0454 using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0' status 1b | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 4000000 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 4000000 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK status 1b | signal 2% | snr 0% | ber 0 | unc -2 | FE_HAS_LOCK И соответственно DVBlast запущенный коммандой ./dvblast -c s2.conf -a 0 -f 11675000 -s 29700000 -m psk_8 с конфигом #<IP>[:<port>] <always on> <SID> [<PID>,]* 239.64.1.1:1234 1 1140 239.64.1.2:1234 1 1153 Замечательно заработал! :) УРА товарищи!!! :) |
15.11.2009, 17:34
Сообщение
#8
Абитуриент Сообщений: 23 Из: Сибирь |
УРА ТОВАРИЩИ!!! Решил проблему! Все оказалось проще. Я думал что в кернеле 2.6.30 используются драйвера от Игоря Леплянинова (s2-liplianin) После установки драйверов от Игоря, szap-s2 стал выводит следующее: И соответственно DVBlast запущенный коммандой Замечательно заработал! :) Думаю, и dvbstreamer теперь будет работать. Можешь его потестировать? |
| Текстовая версия | Сейчас: 31.7.2010, 21:21 |
